Scheduling Automatic Connect/Disconnect
motonyc
Post by motonyc » Mon Jun 06, 2022 7:41 pm
Hi Everyone!
I was wondering if anyone knew of a way to have softether client disconnect and reconnect based on a schedule or task manager using batch file or something similar on Windows PC? Any thoughts would be appreciated!
Thank you!
Re: Scheduling Automatic Connect/Disconnect
Post by solo » Tue Jun 07, 2022 12:38 am
Easy...
@echo off
path=%path%;C:\Program Files\SoftEther VPN Client
vpncmd /CLIENT localhost /CMD AccountRetrySet con-name /NUM:0 /INTERVAL:5
vpncmd /CLIENT localhost /CMD AccountConnect con-name
...and to disconnect: AccountDisconnect
