installation problem
joiwind
Post by joiwind » Wed Jun 08, 2022 7:19 pm
I have just downloaded the latest version to setup on an old XP SP3 box and I'm getting a missing DLL message when running the exe to setup :
"The Entry Point Procedure InterlockedCompareExchange64 cannot be found ..."
Any ideas please ?
Re: installation problem
Post by solo » Thu Jun 09, 2022 2:03 am
SE works on XP, my XP in VirtualBox:
>systeminfo
OS Name:                   Microsoft Windows XP Professional
OS Version:                5.1.2600 Service Pack 3 Build 2600
System Model:              VirtualBox
System type:               X86-based PC
C:\Program Files\SoftEther VPN Server>vpncmd
vpncmd command - SoftEther VPN Command Line Management Utility
SoftEther VPN Command Line Management Utility (vpncmd command)
Version 4.38 Build 9760   (English)
Compiled 2021/08/17 22:32:49 by buildsan at crosswin
By using vpncmd program, the following can be achieved.
1. Management of VPN Server or VPN Bridge
2. Management of VPN Client
3. Use of VPN Tools (certificate creation and Network Traffic Speed Test Tool)
Select 1, 2 or 3: 3
VPN Tools has been launched. By inputting HELP, you can view a list of the comma
nds that can be used.
VPN Tools>check
Check command - Check whether SoftEther VPN Operation is Possible
SoftEther VPN Operation Environment Check Tool
If this operation environment check tool is run on a system and that system pass
es, it is most likely that SoftEther VPN software can operate on that system. Th
is check may take a while. Please wait...
Checking 'Kernel System'...
              Pass
Checking 'Memory Operation System'...
              Pass
Checking 'ANSI / Unicode string processing system'...
              Pass
Checking 'File system'...
              Pass
Checking 'Thread processing system'...
              Pass
Checking 'Network system'...
              Pass
All checks passed. It is most likely that SoftEther VPN Server / Bridge can oper
ate normally on this system.
Perhaps your old PC box is too old?
joiwind
Re: installation problem (SOLVED)
Post by joiwind » Thu Jun 09, 2022 9:41 am
Thanks for the reply. I downloaded an older version which works and will go up through the versions to find the latest without this problem.
goodnews
Post by goodnews » Mon Jul 25, 2022 5:48 am
This is an OpenSSL issue that only affects Build 9772. A patch has already been submitted, and the next SoftEther VPN release is likely going to work again on Windows XP 32-bit: https://github.com/openssl/openssl/issues/18855
