I usually can connect to servers as usual. But today after turning it off and onl again the client doesnt show up (it said something about cant connect on local computer or something like that). Then I delete the client and then re-download it. When i opened it there was no option to connect, only a "add VPN connection". There is usually another option which contains a bunch of servers for me to choose from.
Thank you for your help.
Cannot Connect to any Server
hai1862003
