vpn server
abdorashid6
vpn server
Post by abdorashid6 » Wed Jun 29, 2022 8:37 am
Howdy,
We are utilizing softether verision 4.38 as a vpn server with L2TP. We are utilizing sercure NAT due to DHCP, yet at the same time softether administration is expanding memory utilization in any event, for 10GB and that's only the tip of the iceberg. What would it be advisable for us to check?
Kind Regards
Reason: remove spam:::::: [url=https://testmyspeedy.com/][color=#a9a9a9][size=41]speed test[/size][/color][/url] [url=https://xender.world/][color=#a9a9a9][size=41]xender[/size][/color][/url] [url=https://www.snaptube.fun/][color=#a9a9a9][size=41]snaptube[/size][
Re: vpn server
Post by solo » Wed Jun 29, 2022 12:34 pm
Hello, you have two options:
1/ report the issue here https://github.com/SoftEtherVPN/SoftEtherVPN/issues and hope for a fix in the near future
2/ disable SecureNAT, enable local bridge, and use for example "Open DHCP Server" on Windows (dnsmasq on Linux) - as you can see here, it remedies the problem
