creating the vpn via commandline asking for extra steps
Liam21
Post by Liam21 » Thu Jun 30, 2022 6:02 pm
i used this command.
"c:\program files\softether vpn client\vpncmd.exe" localhost /client /cmd:AccountCreate [myvpn] [/SERVER:32.19.29.64:5555] [/HUB:VPN] [/USERNAME:user1] [/NICNAME:user1]
it works ok and i get this next step
vpncmd command - SoftEther VPN Command Line Management Utility
SoftEther VPN Command Line Management Utility (vpncmd command)
Version 4.39 Build 9772 (English)
Compiled 2022/04/26 18:00:50 by buildsan at crosswin
Connected to VPN Client "localhost".
VPN Client>AccountCreate [myvpn] [/SERVER:82.19.29.64:5555] [/HUB:VPN] [/USERNAME:user1] [/NICNAME:user1]
AccountCreate command - Create New VPN Connection Setting
Destination VPN Server Host Name and Port Number:
so next i manually add
32.19.29.64:5555
then
Destination Virtual Hub Name:
so i add VPN
Destination Virtual Hub Name: VPN
next it ask
Connecting User Name:
i add manually user1
Connecting User Name:user1
next it ask
Used Virtual Network Adapter Name:
i add
Used Virtual Network Adapter Name:VPN
and finally
why do i have to add all this again or am i missing these
please help
Re: creating the vpn via commandline asking for extra steps
Post by solo » Fri Jul 01, 2022 7:28 am
No need to add again, do...
vpncmd localhost /client /cmd AccountCreate myvpn /SERVER:32.19.29.64:5555 /HUB:VPN /USERNAME:user1 /NICNAME:user1
After an account is created, connect like this viewtopic.php?f=7&t=67587
