Install client manually?
Liam21
Post by Liam21 » Fri Jul 01, 2022 7:37 am
How would I install the client manually extract the files from setup.exe ?
I current got windows command to create vpn.
Now I need to also just copy all exe in a folder but am sure am missing out on drivers and services they need to be installed otherwise client will not run.
How cam I do this were are the services drivers and files can I download them manually
Re: Install client manually?
Post by solo » Fri Jul 01, 2022 8:23 am
Perhaps the "Easy Installer Creator" will be useful.
"C:\Program Files\SoftEther VPN Client\vpnsetup.exe" /easy:true
