Hello, community.
It's there in the SoftEther config file a way to modify or add a client CCDs directive and iroute command? I am looking at all options on the SofthEther VPN Manager and I can't find something similar.
I have several dozens of gateways that I have to migrate to SoftEther and those specific brand models do not support uploading OVPN-client configuration from files.
The VPN established can access the server network from the gateway. It's no way to let the client-gateway route its subnet.
Thank you so much.
Best regards,
OVPN CCD Directive-iroute command
pgalarza
