L2TP/IPSec Passthrough traffic over Site-to-Site?
Magoogle
Post by Magoogle » Fri Aug 05, 2022 5:03 pm
I have a Softether server running in a datacenter.
Clients connect to this VPN server over L2TP/IPSec and get assigned a DHCP address from the Firewall of the datacenter network (Same IP range as the server itself 192.168.95.0/24)
The 192.168.95.0/24 network also has access to a 192.168.1.0/24 network over a site-to-site tunnel configured between 2 firewalls.
How can I allow clients of the Softether (192.168.95.0/24) to access clients at the office through the tunnel (192.168.1.0/24)?
Re: L2TP/IPSec Passthrough traffic over Site-to-Site?
Post by solo » Fri Aug 05, 2022 10:32 pm
Do this:
- remove the SE hub's bridge
- enable SecureNAT with all defaults on the hub
Note: the clients can now access the office but not vice-versa.
lichengsi
Post by lichengsi » Mon Jul 08, 2024 8:40 am
hello,Can softether be used to implement site to site?
