problem in different internet
greg2003
Post by greg2003 » Thu Sep 15, 2022 2:45 pm
hi i install on my windows 10 pc the softether vpn , my problem is the pcs in same network connects but if the pcs in different network of server not connected correctly i try to forward ports but it didn't work
Re: problem in different internet
Post by solo » Fri Sep 16, 2022 12:04 am
Check https://clients.dh2i.com/NatTest/ on both server and client.
If any detects "symmetric NAT", NAT-T will not work for sure.
If both detect "permissive NAT", NAT-T may not work because there could be a port restricted NAT.
Since port forwarding also does not work for you, you have two options:
1. VPN Azure (free but slow)
2. your own SoftEther server on a VPS
greg2003
Post by greg2003 » Fri Sep 16, 2022 4:32 pm
ok thanks for reply if detect "permissive NAT" my NAT-T may not work because there could be a port restricted NAT there is a solution to this problem
