Local Bridge - Client DHCP Request not working
toke@xtracon.dk
Post by toke@xtracon.dk » Wed Sep 28, 2022 9:14 am
Hello
I have a Softether VPN, with local bridge, and a Windows DHCP server.
Secure NAT i disabled.
The problem i am facing, is that the clients are getting an IP, and DNS from the DHCP.
But the subnet mask is /32 instead of the /24 that it should be.
And no gateway. (Gateway is 0.0.0.0)
I have sniffed the packets on the Softether server, and i can see that the DHCP server, offers all the info.
But the client just dosent grab everything.
I have tried from different clients, from several networks, and all the same.
Re: Local Bridge - Client DHCP Request not working
Post by solo » Wed Sep 28, 2022 12:30 pm
Your client's setup: "DHCP Enabled. . . . . . . . . . . : No"
So...?
toke@xtracon.dk
Post by toke@xtracon.dk » Wed Sep 28, 2022 2:20 pm
Its Windows In-built VPN
And the properties for the VPN is set to DHCP.
See image.
Its the same on several clients.
Post by solo » Thu Sep 29, 2022 12:23 am
So why did you post it? Confusing.
Post the following after a connection without any firewalls, formatted as code, no pictures:
VPN server
"netstat -r" and "ipconfig /all"
vpncmd localhost:port /server /password:*** /cmd BridgeList
vpncmd localhost:port /server /password:*** /adminhub:@@@ /cmd SecureNatStatusGet
//replace: *** with SE admin password; @@@ with VPN hub's name
VPN client
toke@xtracon.dk
Post by toke@xtracon.dk » Thu Sep 29, 2022 7:41 am
I posted it, so it was visual, what my problem was.
Anyway, as requested.
PS M:\> netstat -r
Interface List
 16...00 50 56 be db 4e ......vmxnet3 Ethernet Adapter
IPv4 Route Table
Active Routes:
          0.0.0.0          0.0.0.0     172.29.160.1    172.29.160.28    271
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
     172.29.160.0    255.255.255.0         On-link     172.29.160.28    271
    172.29.160.28  255.255.255.255         On-link     172.29.160.28    271
   172.29.160.255  255.255.255.255         On-link     172.29.160.28    271
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
        224.0.0.0        240.0.0.0         On-link     172.29.160.28    271
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
  255.255.255.255  255.255.255.255         On-link     172.29.160.28    271
Persistent Routes:
  Network Address          Netmask  Gateway Address  Metric
          0.0.0.0          0.0.0.0     172.29.160.1  Default
IPv6 Route Table
Active Routes:
 If Metric Network Destination      Gateway
  1    331 ::1/128                  On-link
 16    271 fe80::/64                On-link
 16    271 fe80::59c:232b:197a:2ccb/128
                                    On-link
  1    331 ff00::/8                 On-link
 16    271 ff00::/8                 On-link
Persistent Routes:
  None
PS M:\> ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : bms-vpn-intern
   Primary Dns Suffix  . . . . . . . : removed for privacy
   DNS Suffix Search List. . . . . . : removed for privacy
Ethernet adapter BMS_LAN:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : vmxnet3 Ethernet Adapter
   Physical Address. . . . . . . . . : 00-50-56-BE-DB-4E
   Link-local IPv6 Address . . . . . : fe80::59c:232b:197a:2ccb%16(Preferred)
   IPv4 Address. . . . . . . . . . . : 172.29.160.28(Preferred)
   Default Gateway . . . . . . . . . : 172.29.160.1
   DHCPv6 IAID . . . . . . . . . . . : 385896534
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2A-BA-7A-F0-00-50-56-BE-71-43
   DNS Servers . . . . . . . . . . . : 172.29.160.160
                                       172.29.160.47
PS M:\>
PS M:\>
PS M:\> vpncmd localhost /server /password:password /cmd  BridgeList
vpncmd command - SoftEther VPN Command Line Management Utility
SoftEther VPN Command Line Management Utility (vpncmd command)
Version 4.38 Build 9760   (English)
Compiled 2022/02/18 09:01:10 by mp at xtradev
Connection has been established with VPN Server "localhost" (port 443).
You have administrator privileges for the entire VPN Server.
VPN Server>BridgeList
BridgeList command - Get List of Local Bridge Connection
Number|Virtual Hub Name|Network Adapter or Tap Device Name                       |Status
1     |bmsint          |VMware vmxnet3 virtual network device (2) (ID=0630863642)|Operating
PS M:\>
PS M:\>
PS M:\> vpncmd localhost /server /password:password /adminhub:bmsint /cmd SecureNatStatusGet
The Virtual Hub "bmsint" has been selected.
VPN Server/bmsint>SecureNatStatusGet
SecureNatStatusGet command - Get the Operating Status of the Virtual NAT and DHCP Server Function (SecureNat Function)
Item                     |Value
Virtual Hub Name         |bmsint
NAT TCP/IP Sessions      |0 Session
NAT UDP/IP Sessions      |0 Session
NAT ICMP Sessions        |0 Session
NAT DNS Sessions         |0 Session
Allocated DHCP Clients   |0 Client
Kernel-mode NAT is Active|No
Raw IP mode NAT is Active|No
PS M:\>
toke@xtracon.dk
Post by toke@xtracon.dk » Thu Sep 29, 2022 7:53 am
I posted it to visualize my problem.
As requested.
PS M:\> netstat -r
Interface List
IPv4 Route Table
Active Routes:
Persistent Routes:
IPv6 Route Table
Active Routes:
                                    On-link
Persistent Routes:
  None
                                       172.29.160.47
PS M:\>
PS M:\>
PS M:\>
PS M:\>
Item                     |Value
PS M:\>
toke@xtracon.dk
Post by toke@xtracon.dk » Thu Sep 29, 2022 8:10 am
And the client info.
C:\Users\User>netstat -r
Interface List
 13...00 15 5d 01 48 3e ......Microsoft Hyper-V Network Adapter
 28...........................vpnint.bms.dk
 24...5e e7 4c 90 9f 54 ......VPN Client Adapter - VPN
IPv4 Route Table
Active Routes:
          0.0.0.0          0.0.0.0    10.200.201.81    10.200.201.83   4496
          0.0.0.0          0.0.0.0         On-link      172.26.10.32     21
         10.1.1.0    255.255.255.0         On-link      172.26.10.32     21
       10.1.1.255  255.255.255.255         On-link      172.26.10.32    276
    10.200.201.80  255.255.255.248         On-link     10.200.201.83   4496
    10.200.201.83  255.255.255.255         On-link     10.200.201.83   4496
    10.200.201.87  255.255.255.255         On-link     10.200.201.83   4496
        127.0.0.0        255.0.0.0         On-link         127.0.0.1   4556
        127.0.0.1  255.255.255.255         On-link         127.0.0.1   4556
  127.255.255.255  255.255.255.255         On-link         127.0.0.1   4556
      172.26.10.0    255.255.255.0         On-link      172.26.10.32     21
     172.26.10.32  255.255.255.255         On-link      172.26.10.32    276
    172.26.10.255  255.255.255.255         On-link      172.26.10.32    276
     172.29.160.0    255.255.255.0         On-link      172.26.10.32     21
   172.29.160.255  255.255.255.255         On-link      172.26.10.32    276
     212.98.75.41  255.255.255.255    10.200.201.81    10.200.201.83   4241
        224.0.0.0        240.0.0.0         On-link         127.0.0.1   4556
        224.0.0.0        240.0.0.0         On-link     10.200.201.83   4496
        224.0.0.0        240.0.0.0         On-link      172.26.10.32     21
  255.255.255.255  255.255.255.255         On-link         127.0.0.1   4556
  255.255.255.255  255.255.255.255         On-link     10.200.201.83   4496
  255.255.255.255  255.255.255.255         On-link      172.26.10.32    276
Persistent Routes:
          0.0.0.0          0.0.0.0    10.200.201.81  Default
IPv6 Route Table
Active Routes:
 13    271 fe80::/64                On-link
 13    271 fe80::30c2:99de:6cb9:5679/128
                                    On-link
 13    271 ff00::/8                 On-link
Persistent Routes:
  None
C:\Users\User>ipconfig /all
   Host Name . . . . . . . . . . . . : DESKTOP-T1GHP72
   DNS Suffix Search List. . . . . . : bms.dk
Ethernet adapter Ethernet:
   Description . . . . . . . . . . . : Microsoft Hyper-V Network Adapter
   Physical Address. . . . . . . . . : 00-15-5D-01-48-3E
   Link-local IPv6 Address . . . . . : fe80::30c2:99de:6cb9:5679%13(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.200.201.83(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.248
   Default Gateway . . . . . . . . . : 10.200.201.81
   DHCPv6 IAID . . . . . . . . . . . : 218109277
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2A-AA-41-C2-00-15-5D-01-48-3E
   DNS Servers . . . . . . . . . . . : 8.8.8.8
PPP adapter vpnint.redacted for privacy:
   Connection-specific DNS Suffix  . : redacted for privacy
   Description . . . . . . . . . . . : redacted for privacy
   IPv4 Address. . . . . . . . . . . : 172.26.10.32(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.255
   Default Gateway . . . . . . . . . : 0.0.0.0
                                       172.29.160.47
Unknown adapter VPN - VPN Client:
   Description . . . . . . . . . . . : VPN Client Adapter - VPN
   Physical Address. . . . . . . . . : 5E-E7-4C-90-9F-54
C:\Users\User>
Post by solo » Thu Sep 29, 2022 8:49 am
C'mon, I said "...after a connection...", OK?
But before you redo the client, set the following on the server's VM:
promiscuous mode: enabled
mac address changes: enabled
forged transmits: enabled
Let's see what you get now.
toke@xtracon.dk
Post by toke@xtracon.dk » Thu Sep 29, 2022 9:02 am
The Unknown adapter VPN - VPN Client: is used for the Softether VPN client software.
I am not using that.
As i told in the original post, i am using the in-build Windows RAS VPN.
Those are already set on the VM.
Post by solo » Thu Sep 29, 2022 9:15 am
Look mate, are you trolling us, ffs? Here is your other adapter...
With DHCP disabled what did you expect? Think twice before replying.
eddiewu
Post by eddiewu » Thu Sep 29, 2022 4:36 pm
The Windows built-in vpn is PPP-based. That means DHCP is not applicable here. That’s by design.
Post by solo » Thu Sep 29, 2022 6:01 pm
Re-read your original post. You never said that, hence the confusion. Now, ignore the ipconfig, do a ping, your VPN should work just fine.
