problem connecting to l2tp/ipsec softether server from android
irancity
Post by irancity » Wed Sep 28, 2022 1:12 pm
hi
i install softether server on windows 10 and i can connect to server from another windows by softether client software and can connect by openvpn (tcp/443) from android. but have problem to connecting from vpn l2tp/ipsec. sometimes it connect and usually can not connect.
my android version is 12
Re: problem connecting to l2tp/ipsec softether server from android
Post by solo » Wed Sep 28, 2022 1:17 pm
Hello irancity, perhaps it has something to do with the current situation in Iran?
irancity
Post by irancity » Wed Sep 28, 2022 7:28 pm
My problem is different. I can connect through openvpn and I can connect through windows client. But when I try to connect via Android VPN(l2tp/ipsec), it only connects sometimes and most of the time it doesn't connect
irancity
Post by irancity » Thu Sep 29, 2022 2:12 pm
I solved my problem. I could not establish a l2tp connection due to the activation of port 443, which disrupts udp connections. I closed this port and my problem was solved
