Hi
have a windows 10 pc with softether server
i can connect to that pc with openvpn without problem
but i have a cisco anyconnect client in same pc which is connected to another server
i need to route all clients traffic to Cisco TAP adapter
softether server: 192.168.100.50/255.255.255.0/192.168.100.1
cisco tap driver: 20.30.0.90/255.255.255.0/20.30.0.1
i would be grateful if you could help me.
Route all traffic to TAP adapter
Re: Route all traffic to TAP adapter
On W10 start the "Routing and Remote Access" service to enable IP forwarding and that's all.
If it does not work, post as code from the VPN server PC:
netstat -r
ipconfig /all
vpncmd localhost:port /server /password:*** /cmd BridgeList
vpncmd localhost:port /server /password:*** /adminhub:@@@ /cmd SecureNatStatusGet
//replace: *** with SE admin password; @@@ with VPN hub's name
