Can someone help or point me right direction?
I'm new to SoftEther and trying to setup a Site-to-Site VPN, using Layer 3 IP routing.
I have followed the guide "10.6 Build a LAN-to-LAN VPN (Using L3 IP Routing)" but have had no success.
Below is the config I have setup on the bench.
It appears to be connected but I can't access (ping) the other network from either side.
The remote bridge side can't ping the Layer 3 Switch address (192.168.50.250) but the Server side can.
It feels like I am missing some fundamental setting to get this to work.
If there is any missing information needed, please let me know and I will try to provide.
Thanks
SoftEther Server (Windows 10)
Virtual Hub Name: Local
Users: 1 user with password
Bridged to local network card (IP 192.158.0.120)
Virtual Hub Name: Remote
Cascade connection to Local virtual hub
Layer 3 Switch
IP Address 192.168.0.250 /24 virtual hub Local
IP Address 192.168.50.250 /24 virtual hub Remote
Added Route to Server: route add 192.168.50.0 mask 255.255.255.0 192.168.168.0.250
Router forwarding port 5555 to Server (IP 192.168.0.120)
Remote Bridge Server (Windows 10)
Network Card IP: 192.168.50.90
Virtual Hub Connection to DDNS name on Server (with username and password)
Virtual Hub Connecting To: Remote
Added Route to Bridge Server: route add 192.168.0.0 mask 255.255.255.0 192.168.50.250
Router forwarding port 5555 to Bridge Server (IP 192.168.50.90)
Help for a Newbie
Re: Help for a Newbie
Get rid of the internal cascade and routes and apply external static routes.
