Dear All,
i just tested SoftEther yesterday, i am able to install the server on windows machine and a client on windows server 2012R2 and the client was able to connect to the server. when i do the reverse install the SoftEther server on Windows server 2012R2 Machine and install the client on Windows 10 21H2 OS the client can not find the server but also another client installed on another windows can reach only the VPN server installed on Windows 10 but not the one installed on Windows Server 2012R2,
Advise if anyone has fixed this problem, also Note the Server status is Online from Windows Server 2012R2.
VPN Connection
Re: VPN Connection
Sure, we've fixed it numerous times. There is always something wrong with one or more of these...
- VM
- VPS
- LAN
- WAN
- IPv4/IPv6
- 3G/4G/5G/LTE
- CGNAT
- symmetric NAT
- port restricted NAT
- router
- port forwarding
- firewall
- certificate
- encryption
- authentication
- NAT-T
- DDNS
- VPN Azure
- VPN protocol (MS-SSTP, OpenVPN, L2TP/IPsec or native SoftEther)
IT Norvik
Re: VPN Connection
Thanks am able to connect now to my VPN server running on windows server 2012R2 from my LAN but i can not connect to it from outside my LAN, any trick to achieve this?
Re: VPN Connection
VPN Azure, this trick works.
IT Norvik
Re: VPN Connection
I request for some more light in VPN Azure what should i do? i use VPN azure client for connecting from outside my LAN?
