Hello!
SoftEther VPN Server and SoftEther VPN Client are installed on the same computer. The operating system is Windows 10.
When connecting, a VPN connection is created, but without Internet access. Please describe in detail how to fix the problem.
The problem with SoftEther VPN
Re: The problem with SoftEther VPN
"in detail" you ask... here it is - remove the DG (assuming you use this config instead of bridging for the server's access)
