Dear All
I setup a Vpn Server on machine A
And setup a VPN server on Machine B
and defined a cascade connection to machine A
It works greate.
But when I add more cascade connection to machine A from different ports, some times client connection with OpenVPN
show error user authentication failed.
Can any one help me?
User authentication failed multiple cascade connection
datawizard
Re: User authentication failed multiple cascade connection
Look, when I wrote "re-try cascading on various ports", it meant ONE-AT-A-TIME, to check if the fk guards are blocking particular port, of course - NOT MULTIPLE SIMULTANEOUS CASCADES.
datawizard
Thanks for your reply.
My connection is very slow when I use cascade connection.
Perhaps it's because of my restricted network. But I don't know how to understand it.
Also I forced to select VPN over ICMP/DNS because my second VPS is very restricted in my country.
Without these selections, clients have no free internet. But after I select VPN over ICMP/DNS, clients can connect but the connection is very slow.
Do you have any advice to increase performance?
Well, have you tried speed of https://www.vpngate.net/en/ VPNs on 443? Are they blocking the JP and other SoftEther's IPs?
