Hi All,
I have a Softether server correctly setup.
1. ipv4 and ipv6 works correctly on Windows client. (I can see correctly ip at https://test-ipv6.com)
2. ipv4 works correctly without problem on Linux client. (It works after I set correct routing and dhclient)
3. ipv6 is correctly assigned at linux client, I can ping vpn server ipv6 ip.
4. I don't know how to correctly setup Linux client machine ipv6 routing so ipv6 traffice will go through vpn. Can anyone help instruct me?
(static ip setting is not applicable because ipv6 are dynamic ips assign by ISP)
Needs ipv6 instructions on Linux client
Re: Needs ipv6 instructions on Linux client
Feature Stable Edition (SE) Developer Edition (DE) Comment
IPv6-capable VPN Tunnel ! V SE supports IPv6 in L2 VPN tunnels only.
IPv6 Route Management X V Windows clients only
