different between ios client and windows client
siamaknet
Post by siamaknet » Sun Oct 30, 2022 1:10 pm
Hi
i install sstp client on my iphone and its working good , but when install and want to use it from windows , it not work in same internet , can u help me?
Re: different between ios client and windows client
Post by solo » Sun Oct 30, 2022 10:41 pm
Disable firewall, make a VPN connection and post, as code, the output of:
netstat -r
ipconfig /all
vpncmd localhost /client /cmd Check
vpncmd localhost /client /cmd NicList
