Hi everyone and Dear @solo
is there any way to create or have Softether installation or customize it?
I want to install it (Softether Client) with one click in Easy mode including preload profiles.
if there is a way let me know
thanks a lot
Easy Installation included profile
Re: Easy Installation included profile
Hi JellyVPN, it's easy with "easy"...
C:\Program Files\SoftEther VPN Client>vpnsetup.exe /easy:true
How's your SoftEther-with-OpenVPN integration going?Easy Installer Creator is a tool for enterprise administrators. You can create a VPN Client installer with embedding a specific VPN connection setting by using Easy Installer Creator. Personal users can also exploit this tool.
A created Easy Installer can be distributed to employees in the enterprise by using file servers or e-mails. If a user runs the Easy Installer, VPN Client will be installed and the VPN connection setting will be imported, and then the VPN connection will be started automatically.
JellyVPN
MY MEAN IS COMPILING MY INSTALLER FOR MY USERS
what about profiles?
I want to create an easy installation for users, download and install without any changes
they download from my website when installed and opened they have profiles included in the setup, after setup finished when open Softether is from desktop automatically opens in easy mode
Short: customers just install without any knowledge, then start to use
I didn't quite get there I want to haveHow's your SoftEther-with-OpenVPN integration going?
JellyVPN
Dear @solo
I tried with CMD and Powershell it's getting errors, I installed Visual Studio and Build all, but still I can't use my profiles, my Logo and in easy installer, can you explain more with which app or code system how can I run your /easy command?
Hi, try this shortcut...
JellyVPN
Dear @solo Thank you I tried with Developer Edition, but because of that, I couldn't do that, right now with the Stable version I made it, but if I can add more than one profile into one setup it will be great
Can I add more than one profile while creating Installer?
JellyVPN
Dear @solo, if you have any idea, please inform me
