How to get connected with the VPN server
lifefantasia64
I am a new user of this VPN software. I have downloaded the software, but when I tried to connect with VPN server, it requires my username and password. May I know where to register the username?
Re: How to get connected with the VPN server
vhub: VPNGATE
user: vpn
pass: vpn
lifefantasia64
Thank you :_) I tried, still no. I need to choose account type which is standard password or radius or NT certificate. Then what username or password I should use? I tried with vpn, didn't work though.
lifefantasia64
Thank you again. But the problem is I don't know where to register the username or password. I think I lost the admin information. Or can you check for me through Anydesk? I need some help as someone is tracking my computer (a few VPN connection was broken).
11.1.11 I forgot my VPN Server's administrator password.
If you have forgotten the administrator password for your VPN Server, refer to 3.3 VPN Server Administration
and delete the following lines from the VPN Server configuration file with a text editor:
declare ServerConfiguration
uint AutoSaveConfigSpan 30
string CipherName RC4-MD5
bool DisableDosProction false
byte HashedPassword ******* (hashed password data)
As written above, by deleting the [HashedPassword] field under the [ServerConfiguration] node you can reset
the VPN Server password to an empty password.
lifefantasia64
Thank you. Where can I find the server configuration file?
"C:\Program Files\SoftEther VPN Server\vpn_server.config"
Stop the SE service before editing.
lifefantasia64
I can't find VPN server config under that route.
C:\>dir /s vpn_server.config
Directory of C:\Program Files\SoftEther VPN Server
04/11/2022 08:25 PM 14,527 vpn_server.config
1 File(s) 14,527 bytes-
lifefantasia64
Still can't find it ;-)
There is a backup.vpn_client.config, but I can't enter this folder.
Post as code the output of...
net start-
lifefantasia64
Out of my blue. Sorry I am not a computer geek. I probably need someone to remotely operate my computer. @Solo, thank you:-)
I don't think you need your own SE server. Please go to https://www.vpngate.net/en/ where you'll find detailed GUI guides.
lifefantasia64
Thank you again. But I tried with the current two servers Austria and Netherlands, didn't work with the password. And I read through and know how to add the new server. But none works...shit @_@
Try this - uninstall all SoftEther software, reboot, then install VPN Gate Client. Now, no need to enter any passwords, simply click on any VPN server from the list.
Well?
Well?
lifefantasia64
Can't be connected with any server. It shows error code. Don't know what's wrong.
Briefly disable firewall/antivirus on your system and re-try.
lifefantasia64
I give up. I turned off the firewall and it is still the same(*_*)
Johnrider112
To establish a VPN connection to VPN Server, you must create a connection setting. To create a connection setting, select [New Connection Setting] on the [Connect] menu of VPN Client Manager. Hereafter, explanations on creating a connection setting and editing the settings assume this window is open. I hope this will help you.
lifefantasia64
Oh thank you. Yes I open the new connection but it requires to fill other informations such as host name, virtual hub name, server certificate verification options, and user authentication setting of username and password. After all those, then i can click on the OK to establish the connection. What should I fill it up?
Thank you (^_^)
Thank you (^_^)
