Error Code 1
frenchrass
Error Code 1
Post by frenchrass » Fri Nov 04, 2022 1:10 pm
Hello Everyone, hoping I can get some help
My laptop from a different location from the Softether VPN Server is not connecting. I am entering the correct DDNS, TCP/UDP port 5555 is open on router where VPN Server resides. UDP Port 500 and 4500 is also open on router where VPN Server resides. I am able to connect to the VPN with a computer within the network though.
Please Help
Re: Error Code 1
Post by solo » Fri Nov 04, 2022 11:35 pm
Hi, what do you get from the remote PC's browser on https://your.server.addr:5555/
rahulmasal
Re: Error Code 1
Post by rahulmasal » Wed Dec 07, 2022 5:35 pm
Same issue for me also!
in Router we opened 5555 port for server and disabled windows firewall already but without virtual server in router client can connect via 443.
in Server Open Ports
Server Side in Browser Page for 5555
we are using vpnazure service as hostname and using 443 its connecting from outside LAN but via 5555 & other ports not connecting issue!
Re: Error Code 1
Post by solo » Wed Dec 07, 2022 10:29 pm
If you have forwarded ports to the SoftEther server, disabled firewalls, and get nothing from a remote PC's browser on https://your.server.public.ip.addr:5555/ then your ISP does not allow incoming connections.
rahulmasal
Re: Error Code 1
Post by rahulmasal » Thu Dec 08, 2022 4:00 am
Team,
But without port forward using 443 etherServer accessible but using vpnazure.net only.
rahulmasal
Re: Error Code 1
Post by rahulmasal » Thu Dec 08, 2022 4:03 am
so what is alternative solution ?? and how to do that??
Re: Error Code 1
Post by solo » Thu Dec 08, 2022 6:52 am
NAT-T if you're lucky, VPN Azure if you're not in a hurry, or VPS if you can afford it.
