Please help configure the connection from Microtic to vpn server on softether.
I connected without encryption, but I didn't with encryption.
I attach the network diagram, Mikrotik settings. Against a green background, these are filled settings.
Setup port forwarding (dst-nat) for UDP 500, 1701, 4500 for the mikrotik in the Lan with softether.
https://pastebin.com/k3Y26AQ5
Log to connect
https://pastebin.com/QEzrWw7Z
Not connect mikrotik to l2tp VPN softether
sergey113
Re: Not connect mikrotik to l2tp VPN softether
It seems your Mikrotik isn't using IPsec and directly hammering on L2TP port 1701. Post SoftEther's connection log.
