Getting Error on installing Softether server on ubuntu
hrm0081
Post by hrm0081 » Mon Nov 14, 2022 9:29 am
i tried installing Softether server on VPS with Ubuntu (both versions 20 and 22) based on this below tutorial many times.
https://theitguycj.com/installing-softe ... ntu-22-04/
every time after this step:
/etc/init.d/vpnserver start
i get this error :
touch: cannot touch '/var/lock/subsys/vpnserver': No such file or directory
the whole code with the error:
root@ubuntu-g2-small1-sh-1:/usr/local/vpnserver#sudo /etc/init.d/vpnserver start
The SoftEther VPN Server service has been started.
Let's get started by accessing to the following URL from your PC:
https://xx.xx.xx.xx:5555/
  or
https://xx.xx.xx.xx/
Note: IP address may vary. Specify your server's IP address.
A TLS certificate warning will appear because the server uses self signed certificate by default. That is natural. Continue with ignoring the TLS warning.
after the error i cant connect to server and setup the server
i even tried creating the specified path and folder and the error is gone but nothing happens then
Re: Getting Error on installing Softether server on ubuntu
Post by solo » Tue Nov 15, 2022 11:34 pm
That tutorial with ancient /init.d/on 2022 Ubuntu is bizarre. No point struggling with it, scrap it completely and follow this guide which works well with current Ubuntu.
