Maximum speed is around 30-35 Mbps on both sides have 1000 Mbps internet
devrimer
Post by devrimer » Sat Dec 10, 2022 3:21 pm
Hello to all,
Scenario:
Office 1: I have Dell server and running Windows Server 2022 with 1GB fiber optic internet (1:1 GB local and international internet from ISP).
Office 2: there is internet also fiber optic 1GB download / 600 MB upload.
Issue:
I am getting internet speed test result 35mb download / 35mb upload when I connect via SoftEther VPN to the server(office 1) from my other office (office 2) with my desktop PC.
Notes:
- I tested on desktop pc via L2TP and via Softether client app
- secure NAT is enabled on SoftEther software on the server
- all public IP and local IP are static
- all connections are gigabit cable CAT6
- of course there is firewall both offices
- it is not Site-to-Site connection. It is client-to-server connection
I will be happy if someone can help me about my issue,
How can I get more speed on vpn connection ?
Should disable Secure NAT? If yes; then which ports I should add on the firewall device in port forwarding section?
or some different ideas ?
Many thanks!
mjthelearner
Re: Maximum speed is around 30-35 Mbps on both sides have 1000 Mbps internet
Post by mjthelearner » Sat Dec 10, 2022 4:04 pm
try wireguard or v2ray protocoles
Post by solo » Sun Dec 11, 2022 12:26 am
Are you sure about 35Mbps? Because if it is 35MBps then you have OK speed. If you are sure then let's put aside SoftEther for now and do direct speed tests.
What do you get on the server and client from a browser on "speed test" sites?
Next, run NetCPS (port forward and allow in firewall) and quote "Avrg MPS".
For reference, on 1Gb LAN PCs I get around "Avrg MPS: 50" (500Mbs).
devrimer
Post by devrimer » Mon Dec 12, 2022 5:41 am
thanks I will check them too.
devrimer
Post by devrimer » Mon Dec 12, 2022 5:44 am
- What do you get on the server and client from a browser on "speed test" sites?
server: 900mb download /900mb upload
client: 900mb download /600mb upload
I will try NetCPS after working hours. I have active users on the server.
many thanks.
mjthelearner
Post by mjthelearner » Mon Dec 12, 2022 11:02 am
also you can check real speed through the server
sudo apt install speedtest-cli
then run
speedtest
or
speedtest --secure
or you can use fast.com
snap install fast
use command
fast
ctrl+c to cancel
change dns if you had probelm on speedtest
nano /etc/resolv.conf
add
nameserver 1.1.1.1
nameserver 8.8.8.8
then ctrl+x and savey
devrimer
Post by devrimer » Wed Dec 14, 2022 2:05 pm
then run
speedtest
or
speedtest --secure
snap install fast
use command
fast
ctrl+c to cancel
add
nameserver 1.1.1.1
nameserver 8.8.8.8
yes yes I already check that before creating the post. but thanks a lot mate.
KatherineEddie
Post by KatherineEddie » Tue Dec 27, 2022 2:26 pm
Hello to all,
Scenario:
Issue:
Notes:
Many thanks!
Please try this way for testing and post the result.
On server side
- ./vpncmd
- select 3. Use of VPN Tools
- TrafficServer
It start to listen for a client to connect
On client side
- ./vpncmd
- TrafficClient
- it asks you for server IP address , give it the IP address and wait for a test
i will take near 30 minutes.
sample output of mine (it will be reported by client side)
Item Name                                             |        Normal View|Simplified View
Time Span for Measurement                             |       00:00:15.013|
Data Correction for Ethernet Frames                   |                Yes|
Communication Data Volume in Download Direction       |  506,460,938 Bytes|  506.46 MBytes
Communication Data Volume in Upload Direction         |3,125,586,560 Bytes|    3.13 GBytes
Total Communication Data Volume                       |3,632,047,498 Bytes|    3.63 GBytes
Relay Device Input Output Total Throughput Computation|                 No|
Average Throughput in Download Direction              |    269,878,605 bps|    269.88 Mbps
Average Throughput in Upload Direction                |  1,665,536,034 bps|      1.67 Gbps
Total Average Throughput                              |  1,935,414,639 bps|      1.94 Gbps
