Suspend Gateway on Server for Clients?
proxypunker
My clients connect via Azure, but I don't want them to use the internet connection of the server. Is there a way without assigning the clients a static ip address without gateway? Thanks in advance, merry xmas!
Re: Suspend Gateway on Server for Clients?
Otherwise known as "split tunnel":
1) disable SecureNAT, enable local bridge, increase the client's vNIC's metric above regular NIC
or...
2) delete local bridge, enable SecureNAT AND remove its default gateway (AND may have to push static route to the server's LAN)
or, if applicable...
3) in the vNIC uncheck "Use default gateway on remote network"
or...
proxypunker
Thank you so much for your quick help! I gonna try it out and give feedback.
