No send recive
n1986
No send recive
hello,
i have one server as bridge connected to edge server with cascade , becuse of restrictions we use icmp dns request enable on edge server,
i set custom dhcp server for nat on edge,
problem is , 70% of times client connect with openvpn to bridge have internet access and good speed but some times when connect not access to internet and send recive is below 20KB/s need to reconnect to resolve it , where is problem and how i can fix this, appologize for bad english
shakibamoshiri
Re: No send recive
When does this issue happen?n1986 wrote: ↑Sun Jan 22, 2023 10:32 amhello,
- e.g. when +100 users are connected?
- e.g. when most users are OepnVPN not others (there is a bug about OpenVPN in stable version - search github)
Plus share your CC (cascade connection) configuration.
For a few users, CC can be good and performative but for many users Port Forwarding could be better to use maximum capacity of your hop-1 (= bridge server)
See VPN Azure on Github
https://github.com/SoftEtherVPN/SoftEth ... s-Testers)
n1986
Re: No send recive
tnx for ur help, but
my clients connected to bridge server always lower than 50 , 90% connected with open vpn and 10% with l2tp
beacuse of country restriction i cant cascade normal and must enable icmp dns capability of edge server , and this way bridge connected just with
two tcp connection to edge server,
port of bridge and edge are about 500Mb/s and must not any problem with 50 clients , i attached config on both client and bridge ,
I would be grateful if you could provide a suitable solution that has a good speed and solves the problem of not sending and receiving
n1986
Re: No send recive
tnx for ur help, butshakibamoshiri wrote: ↑Sun Jan 22, 2023 1:28 pmWhen does this issue happen?n1986 wrote: ↑Sun Jan 22, 2023 10:32 amhello,
Re: No send recive
For privacy reasons please re-post the data without server passwords, hashes, keys and certificates.
EDIT
Also remove "HashedPassword".
EDIT
Re: No send recive
After a few rounds of redacting, you got it.
shakibamoshiri
Re: No send recive
PLEASE NEVER SHARE THIS WHOLE CONFIGURATION
You could just tell the main options or share like this
declare CascadeList
declare Cascade0
bool CheckServerCert false
bool Online true
declare ClientAuth
uint AuthType X
byte HashedPassword
string Username bridge
declare ClientOption
string AccountName netherlands2
uint AdditionalConnectionInterval 1
uint ConnectionDisconnectSpan 0
string DeviceName _SEHUBLINKCLI_
bool DisableQoS false
bool HalfConnection false
bool HideNicInfoWindow false
bool HideStatusWindow false
string Hostname XXX.XXX.XXX.XXX
string HubName VPN
uint MaxConnection 32
bool NoRoutingTracking true
bool NoTls1 false
bool NoUdpAcceleration false
uint NumRetry 4294967295
uint Port 1886
uint PortUDP 0
string ProxyName $
byte ProxyPassword $
uint ProxyPort 0
uint ProxyType 0
string ProxyUsername $
bool RequireBridgeRoutingMode true
bool RequireMonitorMode false
uint RetryInterval 10
bool UseCompress false
bool UseEncrypt false
declare Policy
bool ArpDhcpOnly false
bool CheckIP false
bool CheckIPv6 false
bool CheckMac false
bool DHCPFilter false
bool DHCPForce false
bool DHCPNoServer false
bool DHCPv6Filter false
bool DHCPv6NoServer false
bool FilterIPv4 false
bool FilterIPv6 false
bool FilterNonIP false
uint MaxDownload 0
uint MaxIP 0
uint MaxIPv6 0
uint MaxMac 0
uint MaxUpload 0
bool NoBroadcastLimiter false
bool NoIPv6DefaultRouterInRA false
bool NoIPv6DefaultRouterInRAWhenIPv6 false
bool NoServer false
bool NoServerV6 false
bool RAFilter false
bool RSandRAFilter false
uint VLanId 0
}I masked your string Hostname XXX.XXX.XXX.XXX
As I said you have two options for hop-1 (to hop-2)
- relying on a tunnel (e.g. SSTP, IPv6-over-IPv4, OpenConnect)
- Port Forwarding
if you can do Port Forwarding , it is better
1. to use the whole capacity of your server and network
2. no need to install SE server on hop-1 (your bridge) since traffic for 443 will be redirected to 443 on hop-2 (your edge)
NOTE
Port Forwarding (or Redirecting Traffic) does not work with all ISPs or DataCenters) you have to test some different servers.
If for any reasons this method did not work or you did not want to use, use method 1 (= CC)
Better CC
- Use an IP instead of Domain in case of not facing DNS name resolving issue
- Use port 443
- Go to Advanced Setting and
--- set TCP connected to 32
--- Enable "Use Half Duplex Mode"
--- Enable "Use Data Comparison"
--- You can disable "Encrypt VPN session with SSL" based on your condition (Be careful with this option)
and OK it
Then in you server hop-1 (= Edge) run the following to check
lsof -ni :443 | grep <YOU EDGE IP ADDRESS> | nl -w 2 -n rz-
n1986
Re: No send recive
i can't connect direct without enable icmp dns on edge server, so i create a kcptun and now bridge connected with 32 connection and half duplex and compress enabled as u say , but port i use is 1886 beacuse 443 taked by softether for administration and cant be tunnel over kcptun,
but i capture traffic and i see bandwidth not go above 50Mb/s after that throttle and slow down, its runing on ubuntu,
is need any config or i must upgrade to developer edition any bug or any, what can i do
shakibamoshiri
Re: No send recive
First, I do not have experience with "kcptun".n1986 wrote: ↑Wed Feb 01, 2023 6:38 ami can't connect direct without enable icmp dns on edge server, so i create a kcptun and now bridge connected with 32 connection and half duplex and compress enabled as u say , but port i use is 1886 beacuse 443 taked by softether for administration and cant be tunnel over kcptun,
Second it might be the "ICMP" limitation using it as tunnel as stated on Windows GUI when you enable it.
So hope others give you a guidance on this.
