Route only SoftEther server traffic through OpenVPN
a.saneie
Hello everyone
I'm running a softether server on debian 11 and I would like to only route the traffic of the softether (not my whole OS) through the openvpn client, from my other server.
Any Idea on how I'll be able to achieve this?
Re: Route only SoftEther server traffic through OpenVPN
The same way like routing through VPN Gate client https://www.vpnusers.com/viewtopic.php? ... 926#p97433
a.saneie
Thanks a lot man @solo
The thing is I don't want any traffic other than Softether to go through OpenVPN that's why I used "pull-filter ignore redirect-gateway" in my OpenVPN client config file but will this line your method is not working anymore.
Go back to the above link and scroll down to "policy-based routing variant".
a.saneie
Thanks a lot @solo
What is 10.245.254.254 representing in that code? should I change it? Also any other part?
I'm wondering how this is gonna help because if I don't include "pull-filter ignore redirect-gateway" in my OpenVPN client config file VPS is gonna be inaccessible and I'll no longer be able to SSH into that, and I'm connecting to openvpn on that with openvpn that I install with "apt install openvpn" I don't know if you had any other way in mind.
10.245.254.254 is a default gateway on the remote (client) connection - adjust accordingly for your OVPN.
a.saneie
So if I understand correctly it's the OVPN server public IP right? or it's the gateway? mine is like:
Public IP of VPS: 155.155.155.155
Public IP of OVPN server: 199.199.199.199
OVPN gateway: 172.25.0.1
OVPN client IP (DHCP): 172.25.0.14
What about "pull-filter ignore redirect-gateway" in my OpenVPN client config file?
- replace 10.245.254.254 with 172.25.0.1
- "pull-filter ignore redirect-gateway" is completely irrelevant in the context of SE-OVPN routing
a.saneie
Thanks man
But if I don't include this in the config file and connect to the OpenVPN client, VPS becomes inaccessible and if I do, VPS softether won't route the traffic through the OpenVPN client.
I think I should explain the situation again:
I got an OPENVPN client config file from a server which got access to the internet. We call it "OVPNfree".
And I also got a Linux VPS which doesn't have access to the internet but can connect to "OVPNfree".
On VPS, I installed Softether and turned on the OPENVPN server so I could connect to it with my phone and PC, which is called "OVPNdomestic".
Now what I want to achieve is to connect softether server which is running on my VPS to "OVPNfree" in a way that doesn't effect anything else on that VPS and doesn't make the SSH and other services on that VPS inaccessible via the public IP of the VPS. So this way if I connect to "OVPNdomestic" with my phone it will have access to the internet. **I cannot directly connect to "OVPNfree" on my phone or PC**
MY PC <=> "OVPNdomestic" VPS (Softether <=> "OVPNfree") <=> "OVPNfree" <=> Internet
If you are absolutely sure that you have adapted the VPN Gate method precisely, and SE server is running, do as follows:
- start OVPN with "pull-filter ignore redirect-gateway"
- from the VPS verify that eg ping 1.1.1.1 is OK
- post as code the output of:
ifconfig
route -n
ip route
ip rule
ip route show table all
iptables -t nat -L
iptables -S
cat /proc/sys/net/ipv4/ip_forward
brctl show
netstat -tapn-
a.saneie
Here you go man:
ifconfig:
root@Gamora:~# ifconfig
docker0: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
inet6 fe80::42:dbff:fed9:3647 prefixlen 64 scopeid 0x20<link>
ether 02:42:db:d9:36:47 txqueuelen 0 (Ethernet)
RX packets 51097 bytes 4786726 (4.5 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 43394 bytes 72691554 (69.3 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
ens192: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500
inet VPS_Public_IP netmask 255.255.255.248 broadcast VPS_Gateway
inet6 fe80::20c:29ff:fe4c:33c5 prefixlen 64 scopeid 0x20<link>
ether 00:0c:29:4c:33:c5 txqueuelen 1000 (Ethernet)
RX packets 241689 bytes 36633431 (34.9 MiB)
TX packets 217314 bytes 31118006 (29.6 MiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 706947 bytes 97328768 (92.8 MiB)
TX packets 706947 bytes 97328768 (92.8 MiB)
tap_tap: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::5c10:beff:fe44:47a7 prefixlen 64 scopeid 0x20<link>
ether 5e:10:be:44:47:a7 txqueuelen 1000 (Ethernet)
RX packets 220 bytes 16426 (16.0 KiB)
TX packets 314 bytes 25924 (25.3 KiB)
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 172.25.0.24 netmask 255.255.255.0 destination 172.25.0.24
inet6 fe80::419d:4821:9441:8e9 prefixlen 64 scopeid 0x20<link>
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 500 (UNSPEC)
RX packets 16905 bytes 2940662 (2.8 MiB)
TX packets 44 bytes 8580 (8.3 KiB)
veth42fa998: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500
inet6 fe80::9c14:e1ff:feb4:f16d prefixlen 64 scopeid 0x20<link>
ether 9e:14:e1:b4:f1:6d txqueuelen 0 (Ethernet)
RX packets 36949 bytes 3977938 (3.7 MiB)
TX packets 31585 bytes 69235311 (66.0 MiB)
veth58ab83d: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500
inet6 fe80::8482:65ff:fef3:ce3d prefixlen 64 scopeid 0x20<link>
ether 86:82:65:f3:ce:3d txqueuelen 0 (Ethernet)
RX packets 84 bytes 54990 (53.7 KiB)
TX packets 177 bytes 21393 (20.8 KiB)
vethbb689a3: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500
inet6 fe80::1023:61ff:fe8a:39c4 prefixlen 64 scopeid 0x20<link>
ether 12:23:61:8a:39:c4 txqueuelen 0 (Ethernet)
RX packets 14064 bytes 1469156 (1.4 MiB)
TX packets 11873 bytes 3464895 (3.3 MiB)
vetheedda44: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500
inet6 fe80::606d:c1ff:fe27:c7d4 prefixlen 64 scopeid 0x20<link>
ether 62:6d:c1:27:c7:d4 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 90 bytes 11944 (11.6 KiB)
route -n:
root@Gamora:~# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 ------------- 0.0.0.0 UG 0 0 0 ens192
------------- 0.0.0.0 255.255.255.248 U 0 0 0 ens192
172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0
172.25.0.0 0.0.0.0 255.255.255.0 U 0 0 0 tun0
root@Gamora:~# ip route
default via ----------- dev ens192 onlink
-------------/29 dev ens192 proto kernel scope link src ---------------
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1
172.25.0.0/24 dev tun0 proto kernel scope link src 172.25.0.24
root@Gamora:~# ip rule
0: from all lookup local
32766: from all lookup main
32767: from all lookup default
root@Gamora:~# ip route show table all
default via --------------- dev ens192 onlink
---------------/29 dev ens192 proto kernel scope link src ---------------
broadcast 127.0.0.0 dev lo table local proto kernel scope link src 127.0.0.1
local 127.0.0.0/8 dev lo table local proto kernel scope host src 127.0.0.1
local 127.0.0.1 dev lo table local proto kernel scope host src 127.0.0.1
broadcast 127.255.255.255 dev lo table local proto kernel scope link src 127.0.0.1
broadcast --------------- dev ens192 table local proto kernel scope link src ---------------
local --------------- dev ens192 table local proto kernel scope host src ---------------
broadcast 172.17.0.0 dev docker0 table local proto kernel scope link src 172.17.0.1
local 172.17.0.1 dev docker0 table local proto kernel scope host src 172.17.0.1
broadcast 172.17.255.255 dev docker0 table local proto kernel scope link src 172.17.0.1
broadcast 172.25.0.0 dev tun0 table local proto kernel scope link src 172.25.0.24
local 172.25.0.24 dev tun0 table local proto kernel scope host src 172.25.0.24
broadcast 172.25.0.255 dev tun0 table local proto kernel scope link src 172.25.0.24
::1 dev lo proto kernel metric 256 pref medium
fe80::/64 dev ens192 proto kernel metric 256 pref medium
fe80::/64 dev docker0 proto kernel metric 256 pref medium
fe80::/64 dev vethbb689a3 proto kernel metric 256 pref medium
fe80::/64 dev vetheedda44 proto kernel metric 256 pref medium
fe80::/64 dev veth58ab83d proto kernel metric 256 pref medium
fe80::/64 dev veth42fa998 proto kernel metric 256 pref medium
fe80::/64 dev tun0 proto kernel metric 256 pref medium
fe80::/64 dev tap_tap proto kernel metric 256 pref medium
local ::1 dev lo table local proto kernel metric 0 pref medium
local fe80::42:dbff:fed9:3647 dev docker0 table local proto kernel metric 0 pref medium
local fe80::20c:29ff:fe4c:33c5 dev ens192 table local proto kernel metric 0 pref medium
local fe80::1023:61ff:fe8a:39c4 dev vethbb689a3 table local proto kernel metric 0 pref medium
local fe80::419d:4821:9441:8e9 dev tun0 table local proto kernel metric 0 pref medium
local fe80::5c10:beff:fe44:47a7 dev tap_tap table local proto kernel metric 0 pref medium
local fe80::606d:c1ff:fe27:c7d4 dev vetheedda44 table local proto kernel metric 0 pref medium
local fe80::8482:65ff:fef3:ce3d dev veth58ab83d table local proto kernel metric 0 pref medium
local fe80::9c14:e1ff:feb4:f16d dev veth42fa998 table local proto kernel metric 0 pref medium
multicast ff00::/8 dev ens192 table local proto kernel metric 256 pref medium
multicast ff00::/8 dev docker0 table local proto kernel metric 256 pref medium
multicast ff00::/8 dev vethbb689a3 table local proto kernel metric 256 pref medium
multicast ff00::/8 dev vetheedda44 table local proto kernel metric 256 pref medium
multicast ff00::/8 dev veth58ab83d table local proto kernel metric 256 pref medium
multicast ff00::/8 dev veth42fa998 table local proto kernel metric 256 pref medium
multicast ff00::/8 dev tun0 table local proto kernel metric 256 pref medium
multicast ff00::/8 dev tap_tap table local proto kernel metric 256 pref medium
root@Gamora:~# iptables -t nat -L
Chain PREROUTING (policy ACCEPT)
target prot opt source destination
DOCKER all -- anywhere anywhere ADDRTYPE match dst-type LOCAL
Chain INPUT (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
DOCKER all -- anywhere !127.0.0.0/8 ADDRTYPE match dst-type LOCAL
Chain POSTROUTING (policy ACCEPT)
MASQUERADE all -- 172.17.0.0/16 anywhere
MASQUERADE tcp -- 172.17.0.2 172.17.0.2 tcp dpt:http
MASQUERADE tcp -- 172.17.0.3 172.17.0.3 tcp dpt:9090
MASQUERADE tcp -- 172.17.0.4 172.17.0.4 tcp dpt:9443
MASQUERADE tcp -- 172.17.0.5 172.17.0.5 tcp dpt:3000
SNAT all -- 192.168.9.0/24 anywhere to:172.25.0.11
SNAT all -- 192.168.9.0/24 anywhere to:172.25.0.24
Chain DOCKER (2 references)
RETURN all -- anywhere anywhere
DNAT tcp -- anywhere anywhere tcp dpt:4968 to:172.17.0.2:80
DNAT tcp -- anywhere anywhere tcp dpt:8984 to:172.17.0.3:9090
DNAT tcp -- anywhere anywhere tcp dpt:9443 to:172.17.0.4:9443
DNAT tcp -- anywhere anywhere tcp dpt:8364 to:172.17.0.5:3000
root@Gamora:~# iptables -S
-P INPUT ACCEPT
-P FORWARD DROP
-P OUTPUT ACCEPT
-N DOCKER
-N DOCKER-ISOLATION-STAGE-1
-N DOCKER-ISOLATION-STAGE-2
-N DOCKER-USER
-A FORWARD -j DOCKER-USER
-A FORWARD -j DOCKER-ISOLATION-STAGE-1
-A FORWARD -o docker0 -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -o docker0 -j DOCKER
-A FORWARD -i docker0 ! -o docker0 -j ACCEPT
-A FORWARD -i docker0 -o docker0 -j ACCEPT
-A OUTPUT ! -s 127.135.138.83/32 ! -d 127.167.27.227/32 -p icmp -m icmp --icmp-type 3/3 -m connmark ! --mark 0x6082458d -j DROP
-A OUTPUT ! -s 127.74.189.243/32 ! -d 127.67.194.175/32 -p tcp -m tcp --sport 61001:65535 --tcp-flags RST RST -m connmark ! --mark 0x5c562f17 -j DROP
-A DOCKER -d 172.17.0.2/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 80 -j ACCEPT
-A DOCKER -d 172.17.0.3/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 9090 -j ACCEPT
-A DOCKER -d 172.17.0.4/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 9443 -j ACCEPT
-A DOCKER -d 172.17.0.5/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 3000 -j ACCEPT
-A DOCKER-ISOLATION-STAGE-1 -i docker0 ! -o docker0 -j DOCKER-ISOLATION-STAGE-2
-A DOCKER-ISOLATION-STAGE-1 -j RETURN
-A DOCKER-ISOLATION-STAGE-2 -o docker0 -j DROP
-A DOCKER-ISOLATION-STAGE-2 -j RETURN
-A DOCKER-USER -j RETURN
root@Gamora:~# cat /proc/sys/net/ipv4/ip_forward
1
root@Gamora:~# brctl show
-bash: brctl: command not found
root@Gamora:~# netstat -tapn
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:4968 0.0.0.0:* LISTEN 963/docker-proxy
tcp 0 0 0.0.0.0:1194 0.0.0.0:* LISTEN 55089/vpnserver
tcp 0 0 127.0.0.1:36011 0.0.0.0:* LISTEN 1382/casaos-app-man
tcp 0 0 0.0.0.0:8364 0.0.0.0:* LISTEN 1033/docker-proxy
tcp 0 0 127.0.0.1:35725 0.0.0.0:* LISTEN 640/casaos-gateway
tcp 0 0 127.0.0.1:45679 0.0.0.0:* LISTEN 640/casaos-gateway
tcp 0 0 0.0.0.0:5555 0.0.0.0:* LISTEN 55089/vpnserver
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 668/sshd: /usr/sbin
tcp 0 0 127.0.0.1:32983 0.0.0.0:* LISTEN 744/casaos-local-st
tcp 0 0 0.0.0.0:8984 0.0.0.0:* LISTEN 990/docker-proxy
tcp 0 0 127.0.0.1:44315 0.0.0.0:* LISTEN 667/casaos
tcp 0 0 127.0.0.1:46175 0.0.0.0:* LISTEN 726/casaos-user-ser
tcp 0 0 0.0.0.0:992 0.0.0.0:* LISTEN 55089/vpnserver
tcp 0 0 0.0.0.0:9443 0.0.0.0:* LISTEN 1011/docker-proxy
tcp 0 0 127.0.0.1:44963 0.0.0.0:* LISTEN 677/casaos-message-
tcp 0 144 ---------------:22 ---------------:49311 ESTABLISHED 54815/sshd: root@pt
tcp 0 39 ---------------:54992 ---------------:443 ESTABLISHED 32851/openvpn
tcp 0 0 127.0.0.1:57222 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:55550 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:33844 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:33052 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:57220 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:55560 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:33832 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:57254 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:33040 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:38260 127.0.0.1:44963 ESTABLISHED 726/casaos-user-ser
tcp 0 0 127.0.0.1:36168 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:55558 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:33442 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:55568 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:33426 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:33030 127.0.0.1:44315 TIME_WAIT -
tcp 197340 0 127.0.0.1:44963 127.0.0.1:38260 ESTABLISHED 677/casaos-message-
tcp 0 0 127.0.0.1:33042 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:33440 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:33430 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:36174 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:33816 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 158.58.191.133:43626 79.127.127.35:443 ESTABLISHED 55089/vpnserver
tcp 0 0 127.0.0.1:36162 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:57238 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:36148 127.0.0.1:44315 TIME_WAIT -
tcp 0 0 127.0.0.1:33858 127.0.0.1:44315 TIME_WAIT -
tcp6 0 0 :::4968 :::* LISTEN 975/docker-proxy
tcp6 0 0 :::1194 :::* LISTEN 55089/vpnserver
tcp6 0 0 :::9100 :::* LISTEN 1205/node_exporter
tcp6 0 0 :::8364 :::* LISTEN 1047/docker-proxy
tcp6 0 0 :::80 :::* LISTEN 640/casaos-gateway
tcp6 0 0 :::5555 :::* LISTEN 55089/vpnserver
tcp6 0 0 :::22 :::* LISTEN 668/sshd: /usr/sbin
tcp6 0 0 :::8984 :::* LISTEN 997/docker-proxy
tcp6 0 0 :::992 :::* LISTEN 55089/vpnserver
tcp6 0 0 :::9443 :::* LISTEN 1018/docker-proxy
tcp6 0 0 ---------------:9100 172.17.0.3:34302 ESTABLISHED 1205/node_exporter
Man, without looking any further, here is the first fundamental error - no IPv4 address!
BTW, edit out your post and redact the public IPs.
a.saneie
Yeah notice that before but didn't know if it was supposed to be like this or not plus IDK how to fix it.
How can I fix this?
Thanks done.
ratepace
SIZE=1 SoftEther Fan
documented already (ExecStartPost=/sbin/ip addr add 192.168.9.1/24 brd + dev tap_tap)
https://www.vpnusers.com/viewtopic.php? ... 072#p98036
answered already
a.saneie
I added this before, and it's not working.solo wrote: ↑Thu Feb 02, 2023 10:49 pmhttps://www.vpnusers.com/viewtopic.php? ... 926#p97433
root@Gamora:~# cat /lib/systemd/system/vpnserver.service
a.saneie
Add some "sleep" prior to the ExecStartPost.
a.saneie
Like this:
ExecStartPost=/bin/sleep 30
yes but not 30 sec, 3 will do
a.saneie
Have another look at the re-routing thread, there are updates.
@fa1rid had successfully applied it in a similar Docker environment as yours https://www.vpnusers.com/viewtopic.php? ... ker#p98207
a.saneie
Sure, I will look into that again, but mine is not the same scenario as his because he is running that client as a docker container, but for me I just have the docker installed on the OS my routing and VPN stuff have nothing to do with it.solo wrote: ↑Mon Feb 13, 2023 1:18 amHave another look at the re-routing thread, there are updates.
Also, I've got a question: should I turn on the "SecureNAT" on VPS Softether or not? (Because when it's off and I connect to the VPS the dhcp doesn't give me an IP)
Although I added this to /etc/dnsmasq.conf
interface=tap_tap
dhcp-range=192.168.9.99,192.168.9.199,12h
dhcp-option=3,192.168.9.1
dhcp-option=6,1.1.1.1
shakibamoshiri
Please ask a new question and do not continue on this topic and provide enough details to discuss your issuea.saneie wrote: ↑Mon Feb 13, 2023 3:15 pm
interface=tap_tap dhcp-range=192.168.9.99,192.168.9.199,12h dhcp-option=3,192.168.9.1 dhcp-option=6,1.1.1.1
Thanks
a.saneie
I asked for clarification over the provided answer on the same topic that it was given.shakibamoshiri wrote: ↑Mon Feb 13, 2023 6:52 pmPlease ask a new question and do not continue on this topic and provide enough details to discuss your issue
Thanks
a.saneie
Still same results :(
I had asked you "If you are absolutely sure that you have adapted the VPN Gate method precisely, and SE server is running, do..." post logs. Back then I pointed out the first critical error and stopped reading your logs. I had another look now and note at least two more flaws:
- the dnsmasq process is not running
- the ip rules are deficient
Apparently you were "absolutely sure" about your implementation but presented a totally dysfunctional setup. Let's try once more - please do your best and post the same set of logs (redact your public IPs). If you have decided to go with SE vDHCP in the current iteration then dnsmasq needs not to run of course.
shakibamoshiri
Sorry I did not check originally its your question.a.saneie wrote: ↑Mon Feb 13, 2023 9:04 pmI asked for clarification over the provided answer on the same topic that it was given.shakibamoshiri wrote: ↑Mon Feb 13, 2023 6:52 pmPlease ask a new question and do not continue on this topic and provide enough details to discuss your issue
Thanks
Can you answer these questions ?
Q1 do you want to implement a double VPN (client ==>. server-1 ===> server-2) ?
Q2 if Q1==YES, you do NOT want to use CC (=Cascade Connection) ? and you want to use OpenVPN client running on your server-1 ?
Q3 if Q2==YES, do you want to run OpenVPN client with full-tunnel or split-tunnel ?
Q4 does the below workflow match your need?
# workflow
clients ===> server-1 ===> server-2
# server-1
SE server + DHCP + Local Bridge (so you have tap_xxx interface ?)
OpenVPN client connected to server-2 (so you have tun0 interface ? )
# server-2
OpenVPN server
based on this workflow you mentioned
You need a double VPN which you can achieve it using any ofMY PC <=> "OVPNdomestic" VPS (Softether <=> "OVPNfree") <=> "OVPNfree" <=> Internet
1. port forwarding from hop-1 (domestic) to hop-2 (your endpoint)
2. Policy Based Routing (PBR) to route traffics
3. Cascade Connection (CC) which SE server makes it super simple
For simplicity sake I have dropped DHCP and got it working with just TWO COMMANDS.
Preset
- Linux server with IP forwarding and no firewall
- SoftEther server in default state with only LBS to soft tap and nothing extra in ExecStart, etc.
- OpenVPN client already running (I connected to VPN Gate)
VPS log
TWO COMMANDS
Windows VPN client on static IP 192.168.9.3
It just works.
Preset
VPS log
ifconfig
tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.242.21.197 P-t-P:10.242.21.198 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
route -n
0.0.0.0 10.242.21.198 128.0.0.0 UG 0 0 0 tun0
0.0.0.0 10.0.2.2 0.0.0.0 UG 0 0 0 enp0s3
10.0.2.0 0.0.0.0 255.255.255.0 U 0 0 0 enp0s3
10.242.21.198 0.0.0.0 255.255.255.255 UH 0 0 0 tun0
128.0.0.0 10.242.21.198 128.0.0.0 UG 0 0 0 tun0
219.100.37.145 10.0.2.2 255.255.255.255 UGH 0 0 0 enp0s3
traceroute 9.9.9.9
traceroute to 9.9.9.9 (9.9.9.9), 30 hops max, 60 byte packets
1 10.242.254.254 (10.242.254.254) 439.534 ms 287.576 ms 362.289 ms
2 gw2.vpngate.v4.open.ad.jp (219.100.37.253) 320.121 ms 320.097 ms 319.435 ms
3 igp1.green.v4.open.ad.jp (202.222.12.190) 581.388 ms 483.662 ms 460.331 ms
4 bgp3.openospf1.v4.open.ad.jp (202.222.12.33) 537.734 ms 624.070 ms 625.069 ms
5 150.99.184.33 (150.99.184.33) 624.062 ms 404.239 ms 325.049 ms
6 150.99.21.21 (150.99.21.21) 382.131 ms 302.935 ms 275.133 ms
7 ty8.gslnetworks.com (103.137.13.76) 352.902 ms 278.624 ms 348.789 ms
8 scrub.ty8.gslnetworks.com (103.137.13.77) 298.470 ms 300.678 ms 320.533 ms
9 203.10.98.35 (203.10.98.35) 313.464 ms 277.452 ms 287.996 ms
10 dns9.quad9.net (9.9.9.9) 287.966 ms !X 265.531 ms !X 277.329 ms !X
TWO COMMANDS
- ifconfig tap_tap 192.168.9.2 netmask 255.255.255.0 promisc arp up
- iptables -t nat -A POSTROUTING -s 192.168.9.0/24 -o tun0 -j MASQUERADE
ping 192.168.9.2
Pinging 192.168.9.2 with 32 bytes of data:
Reply from 192.168.9.2: bytes=32 time=1ms TTL=64
Reply from 192.168.9.2: bytes=32 time<1ms TTL=64
route add 9.9.9.9 mask 255.255.255.255 192.168.9.2
ping 9.9.9.9
Pinging 9.9.9.9 with 32 bytes of data:
Reply from 9.9.9.9: bytes=32 time=291ms TTL=54
Reply from 9.9.9.9: bytes=32 time=289ms TTL=54
Reply from 9.9.9.9: bytes=32 time=292ms TTL=54
tracert 9.9.9.9
Tracing route to dns9.quad9.net [9.9.9.9]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 192.168.9.2
2 502 ms * 469 ms 10.242.254.254
3 370 ms 328 ms 375 ms gw2.vpngate.v4.open.ad.jp [219.100.37.253]
4 405 ms 484 ms 407 ms igp1.green.v4.open.ad.jp [202.222.12.190]
5 379 ms 272 ms 342 ms bgp4.openospf2.v4.open.ad.jp [202.222.12.41]
6 346 ms 383 ms 330 ms 150.99.184.33
7 835 ms 960 ms 568 ms 150.99.21.21
8 609 ms 463 ms 419 ms ty8.gslnetworks.com [103.137.13.76]
9 427 ms 559 ms 446 ms scrub.ty8.gslnetworks.com [103.137.13.77]
10 * 463 ms 360 ms 203.10.98.35
11 588 ms 537 ms 877 ms dns9.quad9.net [9.9.9.9]
Trace complete.
local VPN clients > SoftEther server > OpenVPN client > OpenVPN server somewhere
[----------------VPS----------------]
rakaris
I have the similar case- but I need to route Strongswan traffic.
I have made the following configuration but it's not possible to ping ipcsec tunnel device.
General info
OS Debian 12
2 NICS: one uses strongswan, second uses Softether (clean install)
host that ne4eds to be accessed 192.168.43.100
tap_ens34tap bridge with Softether binded NIC
ip forwarding enabled
tap for Strongswan ipsec tunel (10.20.244.1)
/etc/systemd/system/softether-vpnserver.service
General info
OS Debian 12
/etc/dnsmasq.confsudo tunctl -t tunv
Securenat disabledinterface=tap_ens34tap
dhcp-range=tap_ens34tap,192.168.110.50,192.168.110.60,12h
dhcp-option=tap_ens34tap,3,192.168.110.1
nat[Unit]
Description=SoftEther VPN Server
After=network.target auditd.service
ConditionPathExists=!/opt/vpnserver/do_not_run
[Service]
Type=forking
EnvironmentFile=-/opt/vpnserver
ExecStart=/opt/vpnserver/vpnserver start
ExecStop=/opt/vpnserver/vpnserver stop
KillMode=process
Restart=on-failure
ExecStartPost=/sbin/ip addr add 192.168.110.1/24 brd + dev tap_ens34tap
# Hardening
PrivateTmp=yes
ProtectHome=yes
ProtectSystem=full
ReadOnlyDirectories=/
ReadWriteDirectories=-/opt/vpnserver
CapabilityBoundingSet=CAP_NET_ADMIN CAP_NET_BIND_SERVICE CAP_NET_BROADCAST CAP_NET_RAW CAP_SYS_NICE CAP_SYS_ADMIN CAP_SETUID
[Install]
WantedBy=multi-user.target
Please help me to undestand what is missing!iptables -t nat -A POSTROUTING -s 192.168.110.0/24 -d 192.168.43.100/32 -o tunv -j MASQUERADE
rakaris
I'm stuck and I can't figure out what's wrong.
from VPN session I can ping 10.20.244.1 (Strongswan tunel ip), but can't ping ipsec target on remote subnet.
Any help is appreciated!
Nothing's wrong, NATs are one-way only.
