On the Windows client, if multiple people are using the computer, when one is connected and the signs off, their VPN connection is still open when a different user logs in.
Is there any way to make the VPN client run specific to only a single user, or to automatically disconnect when that user logs out?
I’m not seeing any options for that.
User-specific connection
Re: User-specific connection
[HKEY_CURRENT_USER\Software\Policies\Microsoft\Windows\System\Scripts\Logoff\0\0]
"Script"="C:\Logoff.bat"
"Parameters"=""
"ExecTime"=hex(b):00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
Logoff.bat
"C:\Program Files\SoftEther VPN Client\vpncmd.exe" localhost /client /cmd AccountDisconnect con-name-
jtenos
Thanks. The command works fine, but I think it's not working for me since I'm on Windows 11 Home - no group policy and those keys didn't exist.
I tried Task Scheduler, but apparently that won't work on logoff.
Apparently there are some hacky workarounds, but I don't want to mess with that. Maybe I'll put it on log in of the next user rather than on log out.
Thanks
Thanks
Then edit and import this "Logoff.reg"
REGEDIT4
"Parameters"=""
