Failed to install Virtual Network Adapter
bruhmoment2234
I try to install a virtual network adapter but everytime I try it shows this. Any solutions?
Re: Failed to install Virtual Network Adapter
Install as admin.
ChrisBrooks
The error message suggests a permissions issue. Try running the installation as an admin or checking your user account's permissions to access and install the virtual network adapter. You may also consider reaching out to the adapter's support for further assistance.
