protocol error server return message
yezhouyugon
Post by yezhouyugon » Wed Feb 08, 2023 1:27 pm
I installed softether vpn on win10 computer, the server and client Settings are correct, but the connection failed to display "protocol error server return message". Please help solve it. thank you.
Re: protocol error server return message
Post by solo » Wed Feb 08, 2023 11:52 pm
Tell us more & post logs.
yezhouyugon
Re: Server and client configuration snapshots
Post by yezhouyugon » Thu Feb 09, 2023 2:46 am
This is a screenshot of configuring the server and client. Server host is filled in my own computer ip, other configuration is automatic, I did not change. But it just won't connect. My computer is win10 enterprise version system, is a separate network.
Post by solo » Thu Feb 09, 2023 5:59 am
net stop SEVPNSERVER
nc -l 5555
net start SEVPNSERVER
SoftEther VPN Server Manager
Protocol error occurred. Error was returned from the destination server.
OK
Which means...
- get rid of whatever else is running on SE's port
- or change connection port
BTW, when you've done it you'll discover that running SE client on the same LAN is a horrible idea.
yezhouyugon
Post by yezhouyugon » Thu Feb 09, 2023 1:44 pm
Please check whether my server and client are equipped with que correctly. If the configuration is correct, why the connection fails?
lucas
Post by lucas » Thu Feb 09, 2023 3:10 pm
在服务器选择界面,选择编辑设置,把截图post出来看看,并且在服务器上执行solo说的指令,并且post出结果来
Post by solo » Thu Feb 09, 2023 8:38 pm
Translation?
Anyway, change the port from 443 to 992.
yezhouyugon
Post by yezhouyugon » Fri Feb 10, 2023 4:41 am
I changed port 443 to 991 as suggested, but it still cannot be connected.
yezhouyugon
Still can't connect
Post by yezhouyugon » Fri Feb 10, 2023 6:22 am
Port 443 changed to 992 but still cannot be connected.
yezhouyugon
I can't connect to port 443 after changing it
Post by yezhouyugon » Fri Feb 10, 2023 7:04 am
I can't connect to port 443 after changing it.
Post by solo » Fri Feb 10, 2023 9:46 am
Is it now Error Code 12?
"Access has been denied"?
"Akusesu wa kyohi sa remashita"?
Maybe you forgot your password, check this thread https://www.vpnusers.com/viewtopic.php?f=7&t=5762
yezhouyugon
The password is correct.
Post by yezhouyugon » Sat Feb 11, 2023 9:22 am
The password is correct.It's not the password that's causing the problem.
yezhouyugon
Post by yezhouyugon » Thu Feb 16, 2023 5:31 am
Please check the screenshot. I don't know why I can't connect to the server.
