Hi can you please assist.
I have successfully created a VPN connection between tow sites and I can ping the server from the client.
I have however loaded software that works on a server client basis and it needs port 20111 for the client to connect to the server.
I have tested port 20111 with Telnet and it is not connecting via the VPN.
Can't connect client software to server on port 20111
swanepm1
Re: Can't connect client software to server on port 20111
Enable SecureNAT with all defaults, start VPN and from the client connect to server-private-IP:20111
swanepm1
Thank you, problem solved
