Is this a failed connection?
yezhouyugon
Post by yezhouyugon » Sat Feb 18, 2023 4:24 am
This is always the case. Is the connection not successful? How do you connect successfully?Please see the screenshot
Re: Is this a failed connection?
Post by solo » Sat Feb 18, 2023 6:02 am
It looks failed, a VPN over the same LAN usually fails. I did tell you this before.
https://ja.softether.org/4-docs
yezhouyugon
Post by yezhouyugon » Sat Feb 18, 2023 3:07 pm
How to link correctly? Can you help me?
Post by solo » Sat Feb 18, 2023 10:54 pm
https://www.vpngate.net/ja/
https://www.vpngate.net/cn/
Are you able to link correctly with VPN Gate?
