enable split tunneling IP range
hpathum
Post by hpathum » Thu Mar 09, 2023 6:38 pm
Hi
I am using IPv4 and here are the subnet that i am currently using
Can I know how do I enable the split tunneling for specific IP range
192.168.1.0/24
192.168.2.0/24
192.168.5.0/24
192.168.6.0/24
Re: enable split tunneling IP range
Post by solo » Thu Mar 09, 2023 8:42 pm
It is done with static routing.
hpathum
Post by hpathum » Fri Mar 10, 2023 5:44 am
How do I mention subnet? can you please explain
Post by solo » Fri Mar 10, 2023 8:30 am
It depends on what you have, please describe.
hpathum
Post by hpathum » Fri Mar 10, 2023 5:53 pm
I want to enable split tunneling
but only for a few subnets
Please refer below subnets
192.168.1.0/24
192.168.2.0/24
192.168.5.0/24
192.168.6.0/24
shakibamoshiri
Post by shakibamoshiri » Fri Mar 10, 2023 9:09 pm
You can use "Secure NAT" setting to add static routes to push to a client and tell the client to only "include" routes have been mentioned in "Secure NAT".
but
Including routes relies on clients to add/implement not on a server. So you may set it but see it that did not work. (try it anyway)
The other solution is in client side, "separate" any route or subnet you want. just exclude them before establishing a "full tunnel".
Last edited by shakibamoshiri on Sun Mar 12, 2023 6:14 am, edited 1 time in total.
Post by solo » Sat Mar 11, 2023 10:04 pm
Please refer below subnets ....
Yeah we know these already, describe context: OS, SecureNAT, LBS, L3.
