2 PCs on local LAN, but trafik goes through SE VPN!
PizzaProgram
Remote Server:
version = 5.02 DE
SecureNAT enabled, but gateway + DNS empty !! (no internet access to clients enabled)
10.100.16.1
PC1 + PC2 Clients:
version = 5.02 DE
OS = Windows7 32bit
Local wired LAN, ZTE ISP router : 192.168.1.64 + .1.65 DHCP
SE VPN - FIX IP manually set: 10.111.16.11 + .16.12
Gateway empty, DNS empty
Goal:
- remote support from my PC3 (VNC + RDP) connected as client too.
- not disturbing local LAN communication of PC1 + PC2 !
Problem:
- Since I've installed SE client to both PCs,
- If PC1 is trying to connect to PC2's database (by PC name, on port 3050 )
- the traffic goes through 10.111.16.x (VPN99)
- instead of then normal, 100MBit local LAN (192.168.1.x) !!!
Tried to :
Set metric manually to 1111 (automatic metric turned off)
but did not help :-(
I'm out of ideas.
Had to turn OFF SE VPN client on one of the PCs, as long it is not solved.
(Luckily the old OpenVPN is still up, so I can still connect to those PCs that way...)
version = 5.02 DE
10.100.16.1
PC1 + PC2 Clients:
version = 5.02 DE
OS = Windows7 32bit
Goal:
Problem:
Tried to :
I'm out of ideas.
PizzaProgram
Re: 2 PCs on local LAN, but trafik goes through SE VPN!
10.8.173.0 255.255.255.0 10.8.173.9 10.8.173.10 10 Indirect Static Route 6 394 TAP-Windows Adapter V9 00-FF-F1-F2-D5-11 {F1F2D511-F956-4AF7-BBE6-B04D07AC2954} 29 PcPincerVPN 2023.03.10. 22:23:53 No
10.8.250.0 255.255.255.0 10.8.173.9 10.8.173.10 10 Indirect Static Route 6 394 TAP-Windows Adapter V9 00-FF-F1-F2-D5-11 {F1F2D511-F956-4AF7-BBE6-B04D07AC2954} 29 PcPincerVPN 2023.03.10. 22:23:53 No
10.8.251.0 255.255.255.0 10.8.173.9 10.8.173.10 10 Indirect Static Route 6 394 TAP-Windows Adapter V9 00-FF-F1-F2-D5-11 {F1F2D511-F956-4AF7-BBE6-B04D07AC2954} 29 PcPincerVPN 2023.03.10. 22:23:53 No
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.65 20 Indirect Static Route 6 402 Intel(R) 82579LM Gigabit Network Connection #3 FC-4D-D4-2D-DF-8F {AAB174C0-B5D3-455B-B594-3E29EBD36422} 28 Helyi kapcsolat 2 2023.03.10. 22:23:45 No
130.158.6.110 255.255.255.255 192.168.1.1 192.168.1.65 20 Indirect Static Route 5 209 Intel(R) 82579LM Gigabit Network Connection #3 FC-4D-D4-2D-DF-8F {AAB174C0-B5D3-455B-B594-3E29EBD36422} 28 Helyi kapcsolat 2 2023.03.10. 22:43:38 No
193.201.184.175 255.255.255.255 192.168.1.1 192.168.1.65 20 Indirect Static Route 5 209 Intel(R) 82579LM Gigabit Network Connection #3 FC-4D-D4-2D-DF-8F {AAB174C0-B5D3-455B-B594-3E29EBD36422} 28 Helyi kapcsolat 2 2023.03.10. 22:43:38 No
10.8.173.8 255.255.255.252 10.8.173.10 10.8.173.10 266 Direct Static Route 6 400 TAP-Windows Adapter V9 00-FF-F1-F2-D5-11 {F1F2D511-F956-4AF7-BBE6-B04D07AC2954} 29 PcPincerVPN 2023.03.10. 22:23:47 No
10.8.173.10 255.255.255.255 10.8.173.10 10.8.173.10 266 Direct Static Route 6 400 TAP-Windows Adapter V9 00-FF-F1-F2-D5-11 {F1F2D511-F956-4AF7-BBE6-B04D07AC2954} 29 PcPincerVPN 2023.03.10. 22:23:47 No
10.8.173.11 255.255.255.255 10.8.173.10 10.8.173.10 266 Direct Static Route 6 400 TAP-Windows Adapter V9 00-FF-F1-F2-D5-11 {F1F2D511-F956-4AF7-BBE6-B04D07AC2954} 29 PcPincerVPN 2023.03.10. 22:23:47 No
224.0.0.0 240.0.0.0 10.8.173.10 10.8.173.10 266 Direct Static Route 6 404 TAP-Windows Adapter V9 00-FF-F1-F2-D5-11 {F1F2D511-F956-4AF7-BBE6-B04D07AC2954} 29 PcPincerVPN 2023.03.10. 22:23:43 No
255.255.255.255 255.255.255.255 10.8.173.10 10.8.173.10 266 Direct Static Route 6 404 TAP-Windows Adapter V9 00-FF-F1-F2-D5-11 {F1F2D511-F956-4AF7-BBE6-B04D07AC2954} 29 PcPincerVPN 2023.03.10. 22:23:43 No
192.168.1.0 255.255.255.0 192.168.1.65 192.168.1.65 276 Direct Static Route 6 402 Intel(R) 82579LM Gigabit Network Connection #3 FC-4D-D4-2D-DF-8F {AAB174C0-B5D3-455B-B594-3E29EBD36422} 28 Helyi kapcsolat 2 2023.03.10. 22:23:45 No
192.168.1.1 255.255.255.255 192.168.1.65 192.168.1.65 276 Direct Static Route 5 209 Intel(R) 82579LM Gigabit Network Connection #3 FC-4D-D4-2D-DF-8F {AAB174C0-B5D3-455B-B594-3E29EBD36422} 28 Helyi kapcsolat 2 2023.03.10. 22:43:38 No
192.168.1.65 255.255.255.255 192.168.1.65 192.168.1.65 276 Direct Static Route 6 402 Intel(R) 82579LM Gigabit Network Connection #3 FC-4D-D4-2D-DF-8F {AAB174C0-B5D3-455B-B594-3E29EBD36422} 28 Helyi kapcsolat 2 2023.03.10. 22:23:45 No
192.168.1.255 255.255.255.255 192.168.1.65 192.168.1.65 276 Direct Static Route 6 402 Intel(R) 82579LM Gigabit Network Connection #3 FC-4D-D4-2D-DF-8F {AAB174C0-B5D3-455B-B594-3E29EBD36422} 28 Helyi kapcsolat 2 2023.03.10. 22:23:45 No
224.0.0.0 240.0.0.0 192.168.1.65 192.168.1.65 276 Direct Static Route 6 404 Intel(R) 82579LM Gigabit Network Connection #3 FC-4D-D4-2D-DF-8F {AAB174C0-B5D3-455B-B594-3E29EBD36422} 28 Helyi kapcsolat 2 2023.03.10. 22:23:43 No
255.255.255.255 255.255.255.255 192.168.1.65 192.168.1.65 276 Direct Static Route 6 404 Intel(R) 82579LM Gigabit Network Connection #3 FC-4D-D4-2D-DF-8F {AAB174C0-B5D3-455B-B594-3E29EBD36422} 28 Helyi kapcsolat 2 2023.03.10. 22:23:43 No
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 306 Direct Static Route 6 407 Software Loopback Interface 1 2023.03.10. 22:23:40 No
127.0.0.1 255.255.255.255 127.0.0.1 127.0.0.1 306 Direct Static Route 6 407 Software Loopback Interface 1 2023.03.10. 22:23:40 No
127.255.255.255 255.255.255.255 127.0.0.1 127.0.0.1 306 Direct Static Route 6 407 Software Loopback Interface 1 2023.03.10. 22:23:40 No
224.0.0.0 240.0.0.0 127.0.0.1 127.0.0.1 306 Direct Static Route 6 407 Software Loopback Interface 1 2023.03.10. 22:23:40 No
255.255.255.255 255.255.255.255 127.0.0.1 127.0.0.1 306 Direct Static Route 6 407 Software Loopback Interface 1 2023.03.10. 22:23:40 No
10.111.16.0 255.255.255.0 10.111.16.11 10.111.16.11 1367 Direct Static Route 6 397 VPN Client Adapter - VPN99 5E-03-A3-1A-E2-6F {039B277B-1A62-4B19-A7B3-983A83B4B3FF} 30 PcPincerVPN2 2023.03.10. 22:23:50 No
10.111.16.11 255.255.255.255 10.111.16.11 10.111.16.11 1367 Direct Static Route 6 397 VPN Client Adapter - VPN99 5E-03-A3-1A-E2-6F {039B277B-1A62-4B19-A7B3-983A83B4B3FF} 30 PcPincerVPN2 2023.03.10. 22:23:50 No
10.111.16.255 255.255.255.255 10.111.16.11 10.111.16.11 1367 Direct Static Route 6 397 VPN Client Adapter - VPN99 5E-03-A3-1A-E2-6F {039B277B-1A62-4B19-A7B3-983A83B4B3FF} 30 PcPincerVPN2 2023.03.10. 22:23:50 No
224.0.0.0 240.0.0.0 10.111.16.11 10.111.16.11 1367 Direct Static Route 6 404 VPN Client Adapter - VPN99 5E-03-A3-1A-E2-6F {039B277B-1A62-4B19-A7B3-983A83B4B3FF} 30 PcPincerVPN2 2023.03.10. 22:23:43 No
255.255.255.255 255.255.255.255 10.111.16.11 10.111.16.11 1367 Direct Static Route 6 404 VPN Client Adapter - VPN99 5E-03-A3-1A-E2-6F {039B277B-1A62-4B19-A7B3-983A83B4B3FF} 30 PcPincerVPN2 2023.03.10. 22:23:43 No
How do you know it goes through SE VPN? On PC1, try:
- connect with IP, not PC name
- disconnect OVPN "TAP-Windows Adapter V9"
- disable/stop "Routing and Remote Access" service
shakibamoshiri
If I understood you correctly, you want to access two other PCs without interfering their local connectivity ?
If true
you need a way of implementing split tunneling not full tunneling which means machine X "default route" should not be changed.
Also notice that split tunneling usually are managed at server side not client side.
If you go with client side, then you have to configure it manually.
For SE using SE clients is not a bad idea to achieve your goal but you face these issues you have now :)
solution 1
Reverse SSH port forwarding from client side to managerial side
In this solution a client can share its network completely or partially (over a port) for others
I have used it to do RDP to other people Windows machines (teamviewer , etc ha ha ha -- they use the same technique)
If clients are behind NAT or FW, then a relay server is needed
solution 2
WireGuard peer-2-peer network
In this solution you setup N WGs on N machines and will set "allow-routes" to the clients IP not full route "0.0.0.0/0"
it is more manual but not hard to implement
Many overlay network solution nowadays are using WG
solution 3
OpenConnect client-server
For enterprise OC is the best free VPN servers since supports
- per user configuration
- per group configuration
- has hooks for automation
and split tunneling works really well at server side and users (clients) do not need to do anything.
solution 4
SoftEther VPN server per machines
You can install N SE servers on N machines and connect them together over a single HUB same subnet using cascade connection.
If true
solution 1
solution 2
solution 3
solution 4
PizzaProgram
Thank you for the tips!
> tracert PC2 command shows the way through 10.111.xxx
(I have No control of the routers, nor the IP range, DHCP, etc. of local LANs. Setting Fix IP on the client PC would be suicide if any of that would change and nobody could set back to DHCP as long as I can re-connect from 300Km away anywhere in the country.)
Anyway I don't really understand how that would bring us more near to a permanent solution?
My clients need to work on those PCs in "normal mode" where everything works.
My question is:
It seems that if somehow SE software overrides the default metric behaviour...
It is obvious. My POS pizzaprogram connects + loads the database data 20x slower.How do you know it goes through SE VPN?
No go. I MUST connect with name ! Otherwise I would not need to open this topic. :-Dconnect with IP, not PC name
According to the current routing table it has nothing to do with that, but I'll give a try...disconnect OVPN "TAP-Windows Adapter V9"
I have restarted the PC several time remotely. Can not access booting procedure from far away, also a "waiter girl" or a cook can not assist ... ;-)boot it in "Safe Mode with Networking"
My question is:
- - How is it possible that windows is ignoring local LAN with low metric,
- - and why is it resolving the name of the other PC through the SE VPN as soon as I connect with SE?
- - What are those "windows optimisations" that is SE is performing on first install ?
PizzaProgram
OFF
... my internet connection was down, but now the browser has sent the message I've wrote 12+ hours ago.
Currently that msg. was not allowed to show by a moderator yet, so I can't edit yet.
Since then:
- the original msg I've replied to was edited
- there is a new, more detailed answer
Since then:
Really simple, a diagnostic test which on conclusion may lead to a fix, not a solution of course.PizzaProgram wrote: ↑Sun Mar 12, 2023 1:46 amAnyway I don't really understand how that would bring us more near to a permanent solution?
Next, select "Disable NetBIOS over TCP/IP" in the SE vNIC's advanced properties.
PizzaProgram
YES ! :-)shakibamoshiri wrote: ↑Sat Mar 11, 2023 7:32 amIf I understood you correctly, you want to access two other PCs without interfering their local connectivity ?
Thank you for the long answer!
I'll investigate these possibilities one by one.
Fact:
All the clients (pizza PCs) are behind a local NAT + usually plus the ISP is also using NAT, so there is no way to "direct IP" connection.
That's why I started renting a VPS with public fixed IP, so each client can connect to it from everywhere.
(Even the bosses of those pizzerias from they laptop, wherever they travel.)
At first site:
1. OpenConnect seems to be a great solution
- but I couldn't see a MAC / iOS gui client to it (yet)
- I like SoftEther's GUI much more than writing server-side scripts, like these:
https://gitlab.com/openconnect/recipes/ ... ion-pam.md
managing / writing routing tables of 100 separate groups with different hierarchy seems to be an impossible task at first sight.
2. installing Server to each 200+ clients ... and make all the setup for those one by one...
At first it seems to be a frighteningly overwhelming job, but I think about it. Also
3. So the solution maybe this way:
OK, but how do I set this up from server side ?
- Route Push function of the SecureNAT ?
- Is that function works with client's Fix IP ? or only at DHCP?
(I mean won't it interfere with the concept of: "setting the FIX IPs from client side" as @solo suggested, and I'm currently doing until the DHCP problem is fixed? )
PizzaProgram
THANKS !
Seems to be a great idea !
I do not fully understand what that protocol is doing, but:
- Can I still RDP into that PC after I've disabled it through SE VPN?
But I will test it ...
No problem with RDP.PizzaProgram wrote: ↑Sun Mar 12, 2023 2:26 amTHANKS !
Do it on both SE PCs and either reboot them or run "nbtstat -R" before concluding its effectiveness.
PizzaProgram
@solo
Thank you VERY VERY much for all the help so far!
I have:
I have:
- disabled NetBIOS over TCP
- disabled IPv6
- also unchecked "Register connection address to DNS"
- also unchecked "Search using LMHOSTS"
- RESTARTED both PCs (there was no "nbtstat" command found)
Impossible, it is included in EVERY version of Windows. Search the system folders for it.
Next, on the SE adapter unbind everything except for IPv4. Reboot. If still a problem, post "nbtstat -c"
PizzaProgram
I have no idea how to do an "unbind"
... but I need a bit of sleep first :-D it's 05:40 AM worked the whole night long.
Also the restaurant just opened, so they need the PC now to work on it.
Will continue this afternoon, ca 8-12 hours later.
______________________________________
I have started to disable all kinds of things at Group Sec. policy.
We'll see, if THAT helps
Like this
The pizza shop had closed for sure by now, you can resume the tests :-)PizzaProgram wrote: ↑Sun Mar 12, 2023 4:46 amthe restaurant just opened, so they need the PC now to work on it.
PizzaProgram
Thanks for the picture!
That last one config I may still try later, if that won't disable RDP.
OFF:
But currently I have a government project to finish first.
Our autocratic politicians made a new law, to forcing us to build in to our restaurant program a: "data collection" routine, until end of this month, which must send everything to their server within 1 minute ... All foods, quantity, prices, payment type, times in ms, tip, whatever has been ordered anywhere.
They did that to hotel programs 2 years ago, forcing everyone who enters to show their ID or passport, even if you rent a room for 1 hour with someone, and the owner must scan it via webcam, sending all data to the government immediately.
Since 10 years I started to hate living here at Central Europe / Hungary. Cheated voting system, all TV channels are regulated, no real news, 27% VAT, 48% tax + other hidden taxes, etc.
OFF:
