[SOLVED] Reuse hostname Azure
cramaboule
Post by cramaboule » Thu Mar 23, 2023 7:24 pm
I setup a custom hostname for Azure. I made my tests, and now I want to do setup a real server. I reinstalled the server, imported the configuration file, however the hostname cannot be the same. It says it already in use.
Is there a solution to 'delete' the hostname? Or reuse on the new server?
Thanks in advance!
C.
Re: Reuse hostname Azure
Post by solo » Thu Mar 23, 2023 10:09 pm
A real server's hostname is involved in Azure/DDNS hostname.
https://www.vpnusers.com/viewtopic.php? ... 644#p96372
cramaboule
Post by cramaboule » Fri Mar 24, 2023 9:00 am
Thanks a lot !!!
I found in a backup in backup.vpn_server.config folder the byte Key in the DDnsClient section.
Also when you set up your DDNS name, make sure to save the DNS key! (click on Hint for more explanation)
