Not ping to virtualisation server proxmox
sergey113
On the proxmox server (debian 10), he created a virtual machine with a VPN softether server. Created the Hub and the user in it (certificate login), TAP interface.
BridgeCreate MyHub -device:vpn -tap:yes
Assigned IP TAP to an interface.
ifconfig tap_vpn 192.168.50.15
Prescribed routes.
From a remote client over a VPN link, I cannot ping the proxmox server interface. At the same time, all tap and other interfaces inside the virtual machine itself are available. Firewalls are off.
Perhaps these are restrictions
3.6.11 Points to Note when Local Bridging in Linux, FreeBSD, Solaris or Mac OS X
https://www.softether.org/4-docs/1-manu ... Access_VPN
I prescribed a rule that did not have an effect.
iptables -t nat -A POSTROUTING -s '192.168.50.0/24' -o ens18 -j MASQUERADE
How do I set up ping?
Prescribed routes.
Re: Not ping to virtualisation server proxmox
To work around the Linux kernel VPN ping limitation you need to double-bridge: brctl addif br0 tap_vpn
(BTW, WTF do you redact private-range IPs?)
sergey113
Not works (( No ping to ip proxmox server
/etc/network/interfaces
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
allow-hotplug ens18
iface ens18 inet static
address 192.168.1.15
netmask 24
gateway 192.168.1.1
auto br0
iface br0 inet manual
bridge_ports none
bridge_stp off
bridge_waitport 0
bridge_fd 0
brctl addif br0 tap_art_simple
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
inet 127.0.0.1/8 scope host lo
2: ens18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
inet 192.168.1.15/24 brd 192.168.1.255 scope global ens18
3: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.50.15/24 brd 192.168.50.255 scope global br0
4: tap_art_simple: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master br0 state UNKNOWN group default qlen 1000
Add route
default via 192.168.1.1 dev ens18 onlink
192.168.1.0/24 dev ens18 proto kernel scope link src 192.168.1.15
192.168.40.0/24 via 192.168.50.15 dev br0
192.168.43.0/24 via 192.168.50.15 dev br0
192.168.50.0/24 dev br0 proto kernel scope link src 192.168.50.15
ps
For better security (
sergey113
What do you mean by double bride?
I don`t uderstand. Search only gives out garbage
sergey113
does not work (solo wrote: ↑Sat Apr 08, 2023 2:14 pmLike this https://www.vpnusers.com/viewtopic.php? ... 366#p98366
I make:
ip link add dum0 type dummy
brctl addbr br0
brctl addif br0 dum0 tap_art_simple
ifconfig br0 192.168.100.15 netmask 255.255.255.0 promisc arp up
ip route add 192.168.43.0/24 via 192.168.100.15 dev br0
ip route add 192.168.40.0/24 via 192.168.100.15 dev br0
Interface SE server ens18 have IP 192.168.1.15 he does ping.
Interface proxmox server have IP 192.168.1.10 and and he does not ping
sergey113
SE is poorly compatible with Linux and better look towards other VPNs?
sergey113
I set up a connection in the form of two bridge servers, but this did not help
