Hi everyone, is there an option on the SoftEther server manager app where I can set a static IP for a client? There's one client that I want to always assigned with the same IP everytime it connects.
Thanks in advance.
Re: SoftEther server manager
Not exactly but it is doable with an external DHCP server.
https://www.softether.org/5-download/historyVirtual MAC address reservation
When the user object is using the standard user authentication, you need to write the arbitrary virtual MAC address on the "Note" field on the user object. For example, the "Note" field will have the MAC address format which starts with "MAC:" followed by a 6-bytes ASCII-encoded HEX string, such like "MAC:ae:00:00:00:00:01". We recommend to use the "ae" on the first byte of the MAC address...
