OpenVPN config routes
Umberto
Post by Umberto » Thu Apr 13, 2023 2:06 pm
Hello everyone!
how to allow the user to write his own routes in the ovpn client config?
Now we have:
SecureNAT
string DhcpGatewayAddress 0.0.0.0
string DhcpPushRoutes 192.168.1.0/255.255.255.0/192.168.30.1
We need: inet via user gw, office lan via vpn, user defined IPs (in ovpn config) via vpn
Is it possible?
Re: OpenVPN config routes
Post by solo » Fri Apr 14, 2023 12:08 am
Hi, yes, the user could run a client script with static routes or could connect to a separate VPN hub with modified DhcpPushRoutes.
Umberto
Post by Umberto » Fri Apr 14, 2023 9:37 am
Hi, thanks for the answer! I do modify DhcpPushRoutes (and it works) but the same user`s routes on client`s side doesnt work as if it was firewall on softether server (connection timeout or smtng like that). What`s wrong with my server?)
Post by solo » Fri Apr 14, 2023 12:26 pm
Then let the user connect to a second special-user@VPN2 hub with extra DhcpPushRoutes, whereas everybody else connects to the default VPN hub as usual.
Umberto
Post by Umberto » Fri Apr 14, 2023 2:19 pm
Users say this way to call me every day) We need to make routes at home PCs (by URL)
Umberto
Post by Umberto » Fri Apr 14, 2023 2:22 pm
One more question: How to route 0.0.0.0 mask 0.0.0.0 traffic to home GW when DhcpGatewayAddress is defined (like string DhcpGatewayAddress 192.168.30.1)? I tried a lot and couldn`t understand it, only special hosts and nets.
Post by solo » Fri Apr 14, 2023 10:52 pm
Override 0.0.0.0/0.0.0.0 with eg:
Network Destination        Netmask          Gateway      Interface
            0.0.0.0        128.0.0.0    10.244.18.1      10.244.18.125
          128.0.0.0        128.0.0.0    10.244.18.1      10.244.18.125
Umberto
Post by Umberto » Mon Apr 17, 2023 8:00 am
Hi!
The part of my ovpn file:
route 0.0.0.0 128.0.0.0 net_gateway
route 128.0.0.0 128.0.0.0 net_gateway
part of user connection log:
2023-04-17 10:42:24 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.2.14
2023-04-17 10:42:24 Route addition via service succeeded
2023-04-17 10:42:24 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.2.14
2023-04-17 10:42:24 MANAGEMENT: >STATE:1681717344,ADD_ROUTES,,,,,,
2023-04-17 10:42:24 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 192.168.88.1 METRIC 291
2023-04-17 10:42:24 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 192.168.88.1 METRIC 291
2023-04-17 10:42:24 C:\Windows\system32\route.exe ADD 192.168.1.0 MASK 255.255.255.0 10.8.2.14 METRIC 291
new ip: 10.8.2.13
home gw: 192.168.88.1
"route print":
0.0.0.0 0.0.0.0 192.168.88.1 192.168.88.254 35
0.0.0.0 128.0.0.0 10.8.2.14 10.8.2.13 291
0.0.0.0 128.0.0.0 192.168.88.1 192.168.88.254 326
10.8.2.12 255.255.255.252 On-link 10.8.2.13 291
10.8.2.13 255.255.255.255 On-link 10.8.2.13 291
10.8.2.15 255.255.255.255 On-link 10.8.2.13 291
127.0.0.0 255.0.0.0 On-link 127.0.0.1 331
127.0.0.1 255.255.255.255 On-link 127.0.0.1 331
127.255.255.255 255.255.255.255 On-link 127.0.0.1 331
128.0.0.0 128.0.0.0 10.8.2.14 10.8.2.13 291
128.0.0.0 128.0.0.0 192.168.88.1 192.168.88.254 326
192.168.88.0 255.255.255.0 On-link 192.168.88.254 291
192.168.88.254 255.255.255.255 On-link 192.168.88.254 291
192.168.88.255 255.255.255.255 On-link 192.168.88.254 291
195.94.254.200 255.255.255.255 192.168.88.1 192.168.88.254 291
224.0.0.0 240.0.0.0 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 192.168.88.254 291
224.0.0.0 240.0.0.0 On-link 10.8.2.13 291
255.255.255.255 255.255.255.255 On-link 127.0.0.1 331
255.255.255.255 255.255.255.255 On-link 192.168.88.254 291
255.255.255.255 255.255.255.255 On-link 10.8.2.13 291
BUT first hop in "tracert google.com" is "10.8.2.1"
What wrong am I doing???)))
Post by solo » Mon Apr 17, 2023 10:06 am
Don't use it twice (or do prioritize metric).
Umberto
Post by Umberto » Mon Apr 17, 2023 12:24 pm
Solo, thank you very mach, you are the best))))
Yes, that moment I have duplicated 0.0.0.0 network to push from server and in ovpn client conf.
The metter was in metrics.
Now I have the defined DhcpGatewayAddress, no push routes and part of client ovpn conf:
route 0.0.0.0 128.0.0.0 net_gateway 100
route 128.0.0.0 128.0.0.0 net_gateway 100
route 192.168.1.0 255.255.255.0 vpn_gateway 101
route whatismyip.com 255.255.255.255 vpn_gateway 101
Now thinking how to push "net_gateway" from server...
Umberto
Post by Umberto » Mon Apr 17, 2023 5:25 pm
How to push
route 0.0.0.0 128.0.0.0 net_gateway 2
route 128.0.0.0 128.0.0.0 net_gateway 2
from softether server?)
Post by solo » Tue Apr 18, 2023 1:08 am
Consider a different approach. In ovpn client config add:
route-nopull
#route...
#route...
Umberto
Post by Umberto » Tue Apr 18, 2023 11:09 am
works but no dns from server
Umberto
Post by Umberto » Mon Apr 24, 2023 9:03 am
Hi!
The solution was to leave default gateway in SecureNAT configuration with pushing static route for office network with
pull-filter ignore redirect-gateway
in OVPN user file.
Also now user can write
route myip.com
But they write a little more then I expected)))
