I'm trying to do a vpn connection using 2 laptops with separate providers (prepaid internet).
I configure laptop1 as a vpn server and the other one as client.
I followed softether tutorials and settings posted on youtube but none of them works.
-> https://www.youtube.com/watch?v=cjaIQtQ8q7A
-> https://www.youtube.com/watch?v=zRInkOM0DhQ&t=11s
Is there any step by step configuration/details on how to do it right in windows?
VPN for remote connection (trial and test)
sirch_sandbox
Re: VPN for remote connection (trial and test)
In your context (prepaid internet) there are two steps:
1 - on the server enable VPN Azure
2 - from the client connect to the above address
sirch_sandbox
I followed your advice to use vpnazure.
I got this log issues after the changes:
2023-04-15 09:01:12.270 SSL communication for connection "CID-47-FBBBA999FC" has been started. The encryption algorithm name is "(null)".
2023-04-15 09:01:12.270 [HUB "VPN"] The connection "CID-47-FBBBA999FC" (IP address: [hide ip], Host name: [hide ip], Port number: 59411, Client name: "Microsoft SSTP VPN Client", Version: 4.39, Build: 9772) is attempting to connect to the Virtual Hub. The auth type provided is "External server authentication" and the user name is "test1".
2023-04-15 09:01:12.270 [HUB "VPN"] Connection "CID-47-FBBBA999FC": Successfully authenticated as user "test1".
2023-04-15 09:01:12.270 [HUB "VPN"] Connection "CID-47-FBBBA999FC": The new session "SID-TEST1-[SSTP]-7" has been created. (IP address: [hide ip], Port number: 59411, Physical underlying protocol: "Legacy VPN - SSTP")
2023-04-15 09:01:12.270 [HUB "VPN"] Session "SID-TEST1-[SSTP]-7": The parameter has been set. Max number of TCP connections: 1, Use of encryption: Yes, Use of compression: No, Use of Half duplex communication: No, Timeout: 20 seconds.
2023-04-15 09:01:12.270 [HUB "VPN"] Session "SID-TEST1-[SSTP]-7": VPN Client details: (Client product name: "Microsoft SSTP VPN Client", Client version: 439, Client build number: 9772, Server product name: "SoftEther VPN Server (64 bit)", Server version: 439, Server build number: 9772, Client OS name: "Microsoft SSTP VPN Client", Client OS version: "-", Client product ID: "-", Client host name: "[hide ip]", Client IP address: "[hide ip]", Client port number: 59411, Server host name: "192.168.254.182", Server IP address: "192.168.254.182", Server port number: 60216, Proxy host name: "", Proxy IP address: "0.0.0.0", Proxy port number: 0, Virtual Hub name: "VPN", Client unique ID: "BFDF689A585EE3AFAB3A35CE17121D5A")
2023-04-15 09:01:12.473 SSTP PPP Session [[hide ip]:59411]: Trying to request an IP address from the DHCP server.
2023-04-15 09:01:17.476 SSTP PPP Session [[hide ip]:59411]: Acquiring an IP address from the DHCP server failed. To accept a PPP session, you need to have a DHCP server. Make sure that a DHCP server is working normally in the Ethernet segment which the Virtual Hub belongs to. If you do not have a DHCP server, you can use the Virtual DHCP function of the SecureNAT on the Virtual Hub instead.
2023-04-15 09:01:26.027 SSTP PPP Session [[hide ip]:59411]: The VPN Client sent a packet though an IP address of the VPN Client hasn't been determined.
2023-04-15 09:01:26.027 SSTP PPP Session [[hide ip]:59411]: A PPP protocol error occurred, or the PPP session has been disconnected.
2023-04-15 09:01:26.058 Connection "CID-46-E0DBCCDDD6" terminated by the cause "Connection has been disconnected." (code 3).
How can i fix this issue?
I didn't mention SSTP. I suppose you require more "step by step" steps, here they are https://www.vpnusers.com/viewtopic.php? ... 018#p98965
Don't worry about it being a "VPN gaming guide", just go ahead with the following alterations:
Skip these sections:
Disable other VPN adapters
Disable Routing and Remote Access
Disable SSDP Discovery
Enable DirectPlay and Media Features
Manage Access Lists
Advanced Settings
Change to:
Enable VPN Azure
