Currently accessing internet through a modem with wifi capability, on pc.
I use softether VPN client along with public lists to address the firewall problem.
I would like to make PC a VPN server using Softether VPN server, using VPN server i choses in softether VPN client, so that i can access VPN while on the street, or far away home.
If i am home, i wish to make my VPN connection on PC shared via wifi modem to other devices.
If anyone can at least, point me a way before i jump into text manual. It would be very very helpful.
share my connection
yungboard1024
Follow up :share my connection
Is trying to setup my pc as vpn server that connects from the server i choose in public vpn list
I have setup a "Connection Srttings for VPN server" using localhost, admin mode, Direct TCP/IP, no password.
Using setup wizard, I ticked both "Remote Access VPN server" "Site-to-Site VPN server or VPN Bridge", Ticking "VPN Server that Accepts Connection from Other Sites(center)".
Enabled L2TP RAW, L2TP over IPsec and EtherIP/ L2TPv3.
Ticking VPN AZURE.
Created a user with no password
Concenring Set up local bridge, i found that i have 3 connection,1 is "VPN- VPN Client", other 2 has only 1 connected to internet. SO I choosed the connecting one as bridge.
Which IP do i enter in my IPAD ? I chooses the "dyanimc DNS hostname" in "dynamic DNS Function" > Using IPsec, no proxy, same user name i setup before.
VPN server has no response > change it to IPv4 addres. which is the same as the VPN server i am connecting on public vpn list.
VPN server has no response > changed proxy into manual > 0.0.0.0/0. Same outcome, so as with Dynamic DNS hostname.
I enabled SecureNAT buttion. Resarted Server. Tried the above 2 connection. Same result.
I saw this https://www.softether.org/4-docs/2-howt ... VPN_Server > added TCP 500 and TCP4500. Doesnt work. Same result.
Saw this too. https://www.softether.org/4-docs/2-howt ... Ad-hoc_VPN
Looked up my "SecureNAT Configration" > Entered my IPAD with the IP address in "Virtual Host's Newwork Interace Settings".Conneted. Vpn server has no response.
looked up this https://www.softether.org/4-docs/2-howt ... Bridge_VPN
Go to Manage Casacade Connections > Take this server in public list as example, which i can connect with UDP connection
Standard password vpn vpn
uncheck "diasble NAT-T", Dircet TCP/IP, uncheck "always verify server Certificate", only virtual hub i use.
Port 5555.
DDNS > Error 1
IP > Error 9 user authencation failed
Host name > Error 9
Port 443 > same
HELP
Ticking VPN AZURE.
Port 5555.
DDNS > Error 1
Host name > Error 9
Port 443 > same
HELP
Re: Follow up :share my connection
Neither cascading nor bridging will work because VPN Gate servers' "security policy for the connecting user forbids both bridge mode and router mode".yungboard1024 wrote: ↑Fri May 19, 2023 6:05 amIs trying to setup my pc as vpn server that connects from the server i choose in public vpn list
You need to NAT it, like this https://www.vpnusers.com/viewtopic.php? ... 203#p98750
Or if you prefer a simpler but impermanent solution, go for a hotspot https://www.vpnusers.com/viewtopic.php? ... 625#p96280
yungboard1024
Re: share my connection
i grasped your Referenced post and googled a bit. It looks very technical and i would probably find an aplication for that before actually learning the commands. Thank you very much
