VPN L2 Site2Site Ping only in one way
DerGrafPacula
Post by DerGrafPacula » Fri May 19, 2023 10:05 pm
Hallo from Germany,
ic have created a Site2Site L2 Bridge with SE Server and Bridge:
Site A:
IP Range: 192.168.0.0/24
Domain Controller: 192.168.0.21
Gateway (Lancom): 192.168.0.1
Server VPN SE-Server: 192.168.0.222
Static IP: 88.88.88.88 (for demonastration)
Server: Windows Server 2016 in an Hyper-V Machine
Site B:
Gateway (Lancom): 192.168.0.12
Server VPN SE-Bridge: 192.168.0.13
No IP (LTE)
Bridge Server: Windows 10 bare metal
For the VPN Tunnel IP Range: 10.0.0.0/24
I become a Bridge and i can ping all Devices on Site A from Site B.
BUT: No Devices on Site B from Site A.
As an Example: I had a PC with IP 192.168.0.90 on Site B. From there i can Ping, etc. all Devices on Site A. When i ping 192.168.0.90 from an PC on Site A i become TimeOuts.
On Site B i have enabled NAT/DHCP in the Bridge.
Any ideas?
Many thanks.
Frank
Re: VPN L2 Site2Site Ping only in one way
Post by solo » Sat May 20, 2023 3:20 pm
Hi, on B 192.168.0.90 run
netsh advfirewall firewall set rule name="File and Printer Sharing (Echo Request - ICMPv4-In)" new enable=yes
and check for reciprocal ping. If still unsuccessful, while the VPN is active, post as code:
Site A, VM host of 192.168.0.222:
netstat -r
ipconfig /all
Site A, 192.168.0.222 VM guest:
netstat -r
ipconfig /all
PS>Get-NetAdapter | Format-List -Property ifAlias,InterfaceDescription,PromiscuousMode
vpncmd localhost:port /server /password:*** /cmd BridgeList
vpncmd localhost:port /server /password:*** /adminhub:@@@ /cmd SecureNatStatusGet
Site B, 192.168.0.13:
netstat -r
ipconfig /all
//replace: *** with SE admin password; @@@ with VPN hub's name
nehakakar
Post by nehakakar » Sun Aug 06, 2023 9:56 pm
On Site B, run the following command to enable ICMPv4 echo request (ping) in the Windows Firewall:
Try if this work..
