error:this session is prohibited from routing and only allowed to have no more than 4 IP addresses
15170433259
Post by 15170433259 » Thu May 25, 2023 12:45 pm
2023/5/25 18:47:06
"2023-05-25 18:08:51.831 [HUB "hc-hub"] Session "SID-TEST001-9": Attempted to assign a new IP address "198.18.7.242", but 4 IP addresses have already been assigned to this service. According to the security policy, this session is prohibited from routing and only allowed to have no more than 4 IP addresses. Therefore, the data packet was discarded."
"Due to this error, my IP address of 198.18.7.241 cannot be connected. Has anyone encountered this error before? What should I do to resolve it?"
Re: error:this session is prohibited from routing and only allowed to have no more than 4 IP addresses
Post by solo » Fri May 26, 2023 3:04 am
NetRange: 198.18.0.0 - 198.19.255.255
NetName: SPECIAL-IPV4-BENCHMARK-TESTING-IANA-RESERVED
Addresses starting with "198.18." or "198.19." are set aside for use in isolated laboratory networks used for benchmarking and performance testing. They should never appear on the Internet and if you see Internet traffic using these addresses, they are being used without permission.
You're doing something exquisitely novel.
