The default dynamic DNS domain name xxxx.softether.net is blocked from access
steven1618
Hello, my IP address is changed, not fixed, when I use soft ether server, I need to use the dynamic DNS function, recently I found that the dynamic DNS domain name through the xxxx .softether.net I set is not accessible, I learned through the query that the local network operator blocked the domain address with the suffix xxx.softether.net, resulting in my inability to use. I want to replace the default dynamic DNS service xxx.softether.net domain name with another domain name, so that I can continue to use soft ether, how can I change it?
itskv
Re: The default dynamic DNS domain name xxxx.softether.net is blocked from access
Use any third party dynamic dns service (like noip, afraid etc). No need to use only softether service.
steven1618
Thanks for your reply. Please tell me how to set up the use of third-party dynamic DNS services, such as noip, in softether
