AdHoc connection issue
itskv
Post by itskv » Thu Jun 08, 2023 5:13 pm
1. Whenever I am connecting to server, I am getting this message. But I am pretty sure that I have forwarded port 443,555,1194 and 992 from my VPS server having static IP. What will be the issue? I want clear TCP/IP connection only. UDP acceleration is disabled. Setting "Disable NAT-T" option makes server unreachable by failing the connection retries.
2. Server is configured in AdHoc mode as explained in official guide. All clients can get ping reply from server. But when clients try to ping other client, no ping is replied back. Nor they can communicate with each other by any means.
Server is Ubuntu linux and clients are all Windows 10 or 11.
Re: AdHoc connection issue
Post by solo » Fri Jun 09, 2023 12:16 am
Port 555? Unusual, the ports are not forwarded properly and/or allowed in firewall. Also allow ping in Windows firewall.
itskv
Post by itskv » Fri Jun 09, 2023 12:25 pm
Sorry, typo here. It's 5555.
All ports 443,5555,1194 and 992 are forwarded. Firewall allowed. Ping is enabled.
Post by solo » Fri Jun 09, 2023 1:29 pm
Open a browser and enter https://your-VPS-server-static-IP:5555 - what do you get?
itskv
Post by itskv » Sat Jun 10, 2023 10:47 am
I am not getting any webpage. But I can verify that iptables are allowed and no other firewall is in between.
Post by solo » Sat Jun 10, 2023 11:18 am
Again, "the ports are not forwarded properly and/or allowed in firewall".
Look, we're going in circles. If you are unable to do it properly on Ubuntu, ask for Windows VPS.
itskv
Post by itskv » Sun Jun 11, 2023 5:50 am
I tried all possible solution. Nothing worked.
At last, deleted the VPS instance. Launched fresh VPS instance, installed SE again, edited iptables as per need. Then its stared working.
Thank you @solo for the help.
