I have problems with Add VPN Connection
ALISONA
Post by ALISONA » Sat Jun 10, 2023 6:49 pm
¡Hello!
When I want to connect to an IP of some server, it won't let me connect, Error code 1 appears
I already looked for solutions on Youtube and if it is solved but it reappears and now it no longer lets me connect, but to the "VPN Gate Public VPN Relay Servers" if it lets me do it.
I need a solution please
on Youtube there is no solution
and as i said
this error appears only in "Add VPN connection".
Thank you
Re: I have problems with Add VPN Connection
Post by solo » Sat Jun 10, 2023 11:58 pm
Add this one:
host: public-vpn-185.opengw.net/tcp
port: 443
vhub: VPNGATE
user: vpn
pass: vpn
OK?
ALISONA
Post by ALISONA » Sun Jun 11, 2023 4:24 am
What is the use of adding that server?
ALISONA
Post by ALISONA » Sun Jun 11, 2023 4:49 am
you already added that server now I get error code 2
Post by solo » Sun Jun 11, 2023 5:07 am
public-vpn-185 is for diagnostics and ATM fully operational - there are no errors.
RTFM and re-try.
If/when it works for you, move on to whatever you had tried to connect to initially.
ALISONA
Post by ALISONA » Sun Jun 11, 2023 11:02 pm
Hello, I already added what you told me but now the error code 2 appears
what should I do?
ALISONA
Post by ALISONA » Sun Jun 11, 2023 11:14 pm
Well I was able to connect it with what you told me, and I connected after clicking retry until I connected, I got code 2 error
I put it as a work area network, everything normal
I disconnected it, tried my VPN server and still getting error code 1
and the server that told me no longer connected again
That I have to do?
Post by solo » Sun Jun 11, 2023 11:31 pm
The diagnostic server produces no errors, just checked:
VPN Client>AccountStatusGet public-vpn-185
AccountStatusGet command - Get Current VPN Connection Setting Status
Item                                      |Value
VPN Connection Setting Name               |public-vpn-185
Session Status                            |Connection Completed (Session Established)
VLAN ID                                   |-
Server Name                               |public-vpn-185.opengw.net/tcp
Port Number                               |TCP Port 443
Server Product Name                       |SoftEther VPN Server (64 bit)
Server Version                            |4.32
Server Build                              |Build 9729
Connection Started at                     |2023-06-12 (Mon) 09:22:48
First Session has been Established since  |2023-06-12 (Mon) 09:22:50
Current Session has been Established since|2023-06-12 (Mon) 09:22:50
Number of Established Sessions            |1 Times
I recommend to get this one going first before trying other servers.
ALISONA
Post by ALISONA » Sun Jun 11, 2023 11:44 pm
I think it's weird that it keeps connecting, and I got error code 2 even on that server, I restarted the PC and it connected fast, then I don't connect anymore, what do I do? I do not know what else to do
ALISONA
Post by ALISONA » Sun Jun 11, 2023 11:45 pm
I am trying to connect to the diagnostic server and still the code 2 error appears
Post by solo » Mon Jun 12, 2023 12:15 am
Your ISP or Gov is blocking VPN connections.
