I have a VPN software (LetsVPN) that will only allow me to have 2 devices to connect to my account. I installed its software on a Windows 11 machine, and noticed it created a tap network device for its connection. Is it possible to install SoftEther Server on this Windows 11 computer, so that any client that connects to SoftEther also has its traffic routed through LetsVPN?
Thanks!
How to route SoftEther traffic through another VPN?
xodc
Re: How to route SoftEther traffic through another VPN?
Try to hotspot the tap. As for SE server, it is easily achievable on Linux and we have discussed it numerous times on this forum. It should work on any Windows server edition with RRAS. It may work on W11 with 3rd party software like https://www.nat32.com/
Here is a quick Windows RRAS VPN sharing test without local DHCP, connecting to VPN Gate. LetsVPN or any other service will also work.
[SE client] --->
[SE client] ---> [SE server ---> RRAS ---> SE client] ---> [VPN Gate server]
[SE client] --->
INITIAL SERVER PRESET
- install MLA https://learn.microsoft.com/en-us/troub ... ck-adapter
- assign a static IP to it, eg 192.168.22.2
- bridge SoftEther's hub to it
net stop "Routing and Remote Access"
- connect to VPNGATE
- note VPNGATE routing
- disconnect VPNGATE
net start "Routing and Remote Access"
- enter the route in RRAS "Static Routes" section
- add MLA and VPN NIC in RRAS "NAT/Basic Firewall" section
- set VPN NIC to public interface with NAT
- set MLA to private interface
START VPN SHARING
- check logs
CLIENT VPN CONNECTION TO THE SHARING SERVER
- this test is using a static IP for simplicity
[SE client] --->
[SE client] --->
netstat -r
219.100.37.193 255.255.255.255 10.0.2.2 10.0.2.15 1
START VPN SHARING
- check logs
netstat -r
0.0.0.0 0.0.0.0 10.245.254.254 10.245.90.216 1
10.0.2.0 255.255.255.0 10.0.2.15 10.0.2.15 10
192.168.22.0 255.255.255.0 192.168.22.2 192.168.22.2 30
ipconfig
Ethernet adapter MLA:
IP Address. . . . . . . . . . . . : 192.168.22.2
Ethernet adapter VPN - VPN Client:
IP Address. . . . . . . . . . . . : 10.245.90.216
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 10.245.254.254
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : home
IP Address. . . . . . . . . . . . : 10.0.2.15
ipconfig
Unknown adapter VPN - VPN Client:
IPv4 Address. . . . . . . . . . . : 192.168.22.3
route add 9.9.9.9 mask 255.255.255.255 192.168.22.2
ping 9.9.9.9
Pinging 9.9.9.9 with 32 bytes of data:
Reply from 9.9.9.9: bytes=32 time=434ms TTL=56
Reply from 9.9.9.9: bytes=32 time=383ms TTL=56
Reply from 9.9.9.9: bytes=32 time=562ms TTL=56
Reply from 9.9.9.9: bytes=32 time=333ms TTL=56
tracert 9.9.9.9
Tracing route to dns9.quad9.net [9.9.9.9] over a maximum of 30 hops:
1 3 ms 2 ms 2 ms 192.168.22.2
2 354 ms 321 ms 326 ms 10.245.254.254
3 327 ms 328 ms 327 ms gw2.vpngate.v4.open.ad.jp [219.100.37.253]
4 558 ms 574 ms 592 ms igp1.green.v4.open.ad.jp [202.222.12.190]
5 331 ms 325 ms 338 ms bgp3.openospf1.v4.open.ad.jp [202.222.12.33]
6 361 ms * 328 ms 150.99.184.33
7 376 ms 326 ms 347 ms 150.99.10.187
8 364 ms 341 ms 358 ms as42.ix.jpix.ad.jp [210.171.224.117]
9 420 ms 585 ms 557 ms dns9.quad9.net [9.9.9.9]
Trace complete.You do not have the required permissions to view the files attached to this post.
