SoftEther Server and Manager on MacOS
Tim
Post by Tim » Tue Jul 18, 2023 3:27 am
Has anyone installed SoftEther VPN Server v4.42 on Mac Ventura? Please help.
It seemed the VPN server installation was successful and I could configure it and start it using command line(the VPN Server Manager cannot run on this Mac OS version). But I cannot just make it work. All the clients reported this error:
The L2TP-VPN server did not respond. Try reconnecting. If the problem continues, verify your settings and contact your Administrator.
The configuration was like below. Thanks in advance.
# Software Configuration File
# You may edit this file when the VPN Server / Client / Bridge program is not running.
declare root
	uint ConfigRevision 17
	bool IPsecMessageDisplayed false
	string Region US
	declare DDnsClient
		bool Disabled false
		byte Key wuh0jRxzIHMtfesG0zemiJVmY9A=
		string LocalHostname TWs-MacBook-Pro
		string ProxyHostName $
		uint ProxyPort 0
		uint ProxyType 0
		string ProxyUsername $
	declare IPsec
		bool EtherIP_IPsec true
		string IPsec_Secret tim
		string L2TP_DefaultHub DEFAULT
		bool L2TP_IPsec true
		bool L2TP_Raw false
			declare *
				byte EncryptedPassword mWLj
				string HubName DEFAULT
				string UserName tim
	declare ListenerList
		declare Listener0
			bool DisableDos false
			bool Enabled true
			uint Port 443
		declare Listener1
			bool Enabled true
			uint Port 992
		declare Listener2
			bool Enabled true
			uint Port 1194
		declare Listener3
			bool Enabled true
			uint Port 5555
	declare LocalBridgeList
		declare LocalBridge0
			string DeviceName Tim$20Star
			bool LimitBroadcast false
			bool MonitorMode false
			bool NoPromiscuousMode false
			bool TapMode false
		declare LocalBridge1
			string DeviceName en
			bool TapMode false
		declare LocalBridge2
			string DeviceName en0
			bool TapMode false
	declare ServerConfiguration
		bool AcceptOnlyTls true
		uint AutoSaveConfigSpan 300
		string CipherName AES128-SHA
		uint CurrentBuild 9798
		bool DisableDosProction false
		bool DisableIPsecAggressiveMode false
		bool DisableJsonRpcWebApi false
		bool DisableOpenVPNServer false
		bool DisableSSTPServer false
		bool DontBackupConfig false
		bool EnableVpnAzure false
		bool EnableVpnOverDns false
		bool EnableVpnOverIcmp false
		byte HashedPassword +t4joiEBZlgNYQq4Rb94P+vRT2M=
		uint KeepConnectInterval 50
		uint KeepConnectPort 80
		uint KeepConnectProtocol 1
		uint MaxConcurrentDnsClientThreads 512
		uint MaxConnectionsPerIP 256
		bool NoSendSignature false
		string OpenVPNDefaultClientOption dev-type$20tun,link-mtu$201500,tun-mtu$201500,cipher$20AES-128-CBC,auth$20SHA1,keysize$20128,key-method$202,tls-client
		bool SaveDebugLog false
		byte ServerCert MIID3DCCAsSgAwIBAgIBADANBgkqhkiG9w0BAQsFADBtMR4wHAYDVQQDDBVUV3MtTWFjQm9vay1Qcm8ubG9jYWwxHjAcBgNVBAoMFVRXcy1NYWNCb29rLVByby5sb2NhbDEeMBwGA1UECwwVVFdzLU1hY0Jvb2stUHJvLmxvY2FsMQswCQYDVQQGEwJVUzAeFw0yMzA3MTcxNDE4NTRaFw0zNzEyMzExNDE4NTRaMG0xHjAcBgNVBAMMFVRXcy1NYWNCb29rLVByby5sb2NhbDEeMBwGA1UECgwVVFdzLU1hY0Jvb2stUHJvLmxvY2FsMR4wHAYDVQQLDBVUV3MtTWFjQm9vay1Qcm8ubG9jYWwxCzAJBgNVBAYTAlVTMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAk6mHP4DKUbzjMswc5fl3IMmZG05GBjeC0oWSvyiPTzgMBiqSgbWG/Mnx0j8+/NO8Mb23k4dhn3BqQifAPRsE8YzNsEN2JukYBQHWG6u+FaOH81Tej/81+qAOogjUl1tMGwTNCadNIg+D/OpC2lpTxt21oDwryxTtgebNsMnHTxK+qiK+xnfcM6d2b0vJ9XlC35V+dg2HIQG4iv5nekR6JIbV5Pq229HhMh0PlKWJy+RU48DzMMSIXXvjAKNHLOeMqP4yvEo2YlOg/qBoxHT0lObszXMr87r0rGYu63W+TBCrPoBHfqBlURu5vLm1nZIBEKKcGGuKcIj0RY2rRKkG0wIDAQABo4GGMIGDMA8GA1UdEwEB/wQFMAMBAf8wCwYDVR0PBAQDAgH2MGMGA1UdJQRcMFoGCCsGAQUFBwMBBggrBgEFBQcDAgYIKwYBBQUHAwMGCCsGAQUFBwMEBggrBgEFBQcDBQYIKwYBBQUHAwYGCCsGAQUFBwMHBggrBgEFBQcDCAYIKwYBBQUHAwkwDQYJKoZIhvcNAQELBQADggEBAI8IB6MMe1oxrEAs9pMWECb07miY/jpVwN+L/myygRvWtMfxcYVzP28YjGv/7b4aq4g5e9w9dHABuwkerTjtz86Pm10I8X+ceQz9aSvYwf+BBMvMpZwf4fVbqKt+v96DmP3gKrERN+ltMVeOF3KpumYJEadUD6n/CBEGnXBPfJz3dT4ZkalxPeWShYInLkqsnqhGTQfGcE7kRLXC703e+pPLSbeKLm6dzRfXHfFzbnph41/DFb/iaMTXcoG5MamI7O3SlS5tOYBjrQd++MkqCHueUHPEIbiWCb6B+moniFp08c806CLbsm0M8upmu+CqbGz/sNtdqsPm1IsN3A1hZO0=
		byte ServerKey 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
		uint ServerLogSwitchType 4
		uint ServerType 0
		bool StrictSyslogDatetimeFormat false
		bool Tls_Disable1_0 false
		bool Tls_Disable1_1 false
		bool Tls_Disable1_2 false
		bool Tls_Disable1_3 false
		bool UseKeepConnect true
		bool UseWebTimePage false
		bool UseWebUI false
		declare GlobalParams
			uint FIFO_BUDGET 10240000
			uint MAX_BUFFERING_PACKET_SIZE 2560000
			uint MAX_HUB_LINKS 1024
			uint MAX_IP_TABLES 65536
			uint MAX_MAC_TABLES 65536
			uint MAX_SEND_SOCKET_QUEUE_SIZE 2560000
			uint MAX_STORED_QUEUE_NUM 1024
			uint MEM_FIFO_REALLOC_MEM_SIZE 655360
			uint MIN_SEND_SOCKET_QUEUE_SIZE 320000
			uint QUEUE_BUDGET 2048
			uint SELECT_TIME 256
			uint SELECT_TIME_FOR_NAT 30
			uint STORM_CHECK_SPAN 500
		declare ServerTraffic
			declare RecvTraffic
				uint64 BroadcastBytes 1473316
				uint64 BroadcastCount 4789
				uint64 UnicastBytes 376293529
				uint64 UnicastCount 477339
			declare SendTraffic
				uint64 BroadcastBytes 2946632
				uint64 BroadcastCount 9578
				uint64 UnicastBytes 1291804
				uint64 UnicastCount 20829
		declare SyslogSettings
			string HostName $
			uint Port 0
			uint SaveType 0
	declare VirtualHUB
		declare DEFAULT
			uint64 CreatedTime 1689571134483
			byte HashedPassword +WzqGYrR3VYXrAhKPZLGEHcIwO8=
			uint64 LastCommTime 1689571134482
			uint64 LastLoginTime 1689571134482
			uint NumLogin 0
			bool Online true
			string RadiusRealm $
			uint RadiusRetryInterval 0
			uint RadiusServerPort 1812
			string RadiusSuffixFilter $
			byte SecurePassword bpw3X/O5E8a6G6ccnl4uXmDtkwI=
			uint Type 0
			declare AccessList
			declare AdminOption
				uint deny_bridge 0
				uint deny_empty_password 0
				uint deny_qos 0
				uint deny_routing 0
				uint max_accesslists 0
				uint max_bitrates_download 0
				uint max_bitrates_upload 0
				uint max_groups 0
				uint max_sessions 0
				uint max_sessions_bridge 0
				uint max_sessions_client 0
				uint max_users 0
				uint no_cascade 0
				uint no_change_access_list 0
				uint no_change_cert_list 0
				uint no_change_crl_list 0
				uint no_change_groups 0
				uint no_change_log_config 0
				uint no_change_msg 0
				uint no_change_users 0
				uint no_delete_iptable 0
				uint no_delete_mactable 0
				uint no_disconnect_session 0
				uint no_enum_session 0
				uint no_offline 0
				uint no_online 0
				uint no_query_session 0
				uint no_read_log_file 0
				uint no_securenat 0
				uint no_securenat_enablenat 0
			declare CascadeList
			declare LogSetting
				uint PacketLogSwitchType 4
				uint PACKET_LOG_ARP 0
				uint PACKET_LOG_DHCP 1
				uint PACKET_LOG_ETHERNET 0
				uint PACKET_LOG_ICMP 0
				uint PACKET_LOG_IP 0
				uint PACKET_LOG_TCP 0
				uint PACKET_LOG_TCP_CONN 1
				uint PACKET_LOG_UDP 0
				bool SavePacketLog true
				bool SaveSecurityLog true
				uint SecurityLogSwitchType 4
			declare Message
			declare Option
				uint AdjustTcpMssValue 0
				bool DisableHttpParsing false
				bool DisableIPParsing false
				bool DisableIpRawModeSecureNAT false
				bool FilterBPDU false
				bool FilterIPv4 false
				bool FilterIPv6 false
				bool FilterNonIP false
				bool FilterOSPF false
				bool FilterPPPoE false
				bool ManageOnlyPrivateIP true
				uint MaxSession 0
				bool NoArpPolling false
				bool NoEnum false
				bool NoIpTable false
				bool NoIPv4PacketLog false
				bool NoIPv6AddrPolling false
				bool NoIPv6PacketLog false
				bool NoLookBPDUBridgeId false
				bool NoMacAddressLog true
				bool NoManageVlanId false
				uint RequiredClientId 0
				string VlanTypeId 0x8100
			declare SecureNAT
				bool Disabled true
				bool SaveLog true
				declare VirtualDhcpServer
					string DhcpDomainName $
					bool DhcpEnabled true
					uint DhcpExpireTimeSpan 7200
					string DhcpLeaseIPEnd 192.168.30.200
					string DhcpLeaseIPStart 192.168.30.10
					string DhcpPushRoutes $
				declare VirtualHost
					string VirtualHostMacAddress 5E-84-4E-49-44-7C
				declare VirtualRouter
					bool NatEnabled true
					uint NatMtu 1500
					uint NatTcpTimeout 1800
					uint NatUdpTimeout 60
				declare CertList
				declare CrlList
				declare GroupList
				declare IPAccessControlList
				declare UserList
					declare tim
						byte AuthNtLmSecureHash THFN++bOk6V53sda7LMbNA==
						byte AuthPassword Tsm2d8+gjrCI4x98YiPUnnLqS2I=
						uint AuthType 1
						uint64 CreatedTime 1689602586204
						uint64 ExpireTime 0
						uint64 LastLoginTime 0
						string Note admin
						uint NumLogin 0
						string RealName tim
						uint64 UpdatedTime 1689602743973
						declare Traffic
							declare RecvTraffic
								uint64 BroadcastBytes 0
								uint64 BroadcastCount 0
								uint64 UnicastBytes 0
								uint64 UnicastCount 0
							declare SendTraffic
			declare Traffic
				declare RecvTraffic
				declare SendTraffic
Re: SoftEther Server and Manager on MacOS
Post by solo » Tue Jul 18, 2023 6:58 am
Enable VPN Azure and using a Windows SE client try to connect to your Azure address. If it works, we'll discuss next steps.
Btw, you can use VPN Server Manager remotely from a Windows or Linux/Wine PC.
Tim
Post by Tim » Tue Jul 18, 2023 9:11 am
Thanks Solo. I am not sure I am doing it correctly or not. I was getting this.
VPN Server/DEFAULT>VpnAzureSetEnable Enable
VpnAzureSetEnable command - Enable / Disable VPN Azure Function
VPN Server/DEFAULT>VpnAzureGetStatus
VpnAzureGetStatus command - Show the current status of VPN Azure function
Item                         |Value
VPN Azure Function is Enabled|No
Post by solo » Tue Jul 18, 2023 11:53 am
incorrect
6.3.85 "VpnAzureSetEnable": Enable / Disable VPN Azure Function
Command Name 	VpnAzureSetEnable
Purpose 	Enable / Disable VPN Azure Function
Description 	Enable or disable the VPN Azure function.
VPN Azure makes it easier to establish a VPN Session from your home PC to your office PC. While a VPN connection is established, you can access to any other servers on the private network of your company.
You don't need a global IP address on the office PC (VPN Server). It can work behind firewalls or NATs. No network administrator's configuration required. You can use the built-in SSTP-VPN Client of Windows in your home PC.
VPN Azure is a cloud VPN service operated by SoftEther Corporation. VPN Azure is free of charge and available to anyone. Visit http://www.vpnazure.net/ to see details and how-to-use instructions.
The VPN Azure hostname is same to the hostname of the Dynamic DNS setting, but altering the domain suffix to "vpnazure.net". To change the hostname use the DynamicDnsSetHostname command.
To execute this command, you must have VPN Server administrator privileges.
This command cannot be run on VPN Bridge.
You cannot execute this command for Virtual Hubs of VPN Servers operating as a cluster.
Command-line 	VpnAzureSetEnable [yes|no]
Arguments for "VpnAzureSetEnable": yes|no
Specify 'yes' to enable VPN Azure. 'no' to disable it.
Maybe try to manage it via GUI from another PC on LAN/WiFi.
Tim
Post by Tim » Tue Jul 18, 2023 10:17 pm
Thanks. Will try.
I might try using dock image first to make things easier.
Thanks very much for the help.
