Requirements for softether
cnbbs
Post by cnbbs » Thu Jul 20, 2023 2:03 pm
Hi.
I'm trying to use softether client on my laptop at home to connect to softether server on my laptop at the office but with no success.
If I connect the laptop running the server to a different network I can connect to it, but whenever it's at the office, I can't, the client gets an error 1, to check the port or connection settings. I tried the different ports but still nothing. The ddns is working and I can ping the office IP.
I know there's a mikrotik routerboard as the gateway at the office, could that be the problem? If so, what configuration would need to be checked or corrected?
Unfortunately the IT guy doesn't know where to begin either or what to check, since softether is supposed to go through firewalls.
Can anyone please help?
If there's more details needed, let me know.
Any help is appreciated.
Thank you.
Re: Requirements for softether
Post by solo » Thu Jul 20, 2023 2:36 pm
If you can not sort it out with the IT, enable VPN Azure and connect with SE client to the address.
