About the problem of "SoftEther VPN" causing the blue screen of Windows 11 system
LeeHS
Post by LeeHS » Tue Jul 25, 2023 7:33 am
After changing the CPU, power supply, system, and motherboard of my computer, the blue screen still appears. Finally, I analyzed the .dmp file with the help of Microsoft Community and found that it was caused by SoftEther VPN. How can I provide logs to help troubleshoot the issue? Or is the software no longer updated?
I only enabled Open VPN/MS-SSTP, Dynamic DNS and local bridging to the VPN server.
CPU is Ryzen 9 5950x.
OS version is Windows 11 22621.1992
Re: About the problem of "SoftEther VPN" causing the blue screen of Windows 11 system
Post by solo » Tue Jul 25, 2023 9:05 am
What about NIC, Realtek maybe?
LeeHS
Post by LeeHS » Tue Jul 25, 2023 10:47 am
It is Realtek PCIe 2.5GbE Family Controller.
The driver version is 1125.10.720.2022
Post by solo » Tue Jul 25, 2023 10:54 am
Then try a non-Realtek PCIe or USB NIC.
LeeHS
Post by LeeHS » Tue Jul 25, 2023 12:39 pm
I tried to use Mellanox CX341A as the main network card before, but a blue screen still appeared. But didn't realize at the time that the blue screen was caused by the VPN, not the NIC.
LeeHS
Post by LeeHS » Tue Jul 25, 2023 2:49 pm
Before the blue screen, my SoftEther version was 4.41, and now it has been upgraded to 4.42. Hope that helps. .
Post by solo » Tue Jul 25, 2023 2:53 pm
Proceed with 'developer' test. A bit tricky there, if you can't find your way, click https://dev.azure.com/SoftEther-VPN/Sof ... dArtifacts
LeeHS
Post by LeeHS » Tue Jul 25, 2023 3:05 pm
That means I might be better off choosing developer? This may take some time as I have some settings on the stable release that need to be relocated. (Although the current stable version experience is not good, it is at least useful)
Post by solo » Tue Jul 25, 2023 3:15 pm
Backup your "vpn_server.config" and you'll be fine.
LeeHS
Post by LeeHS » Thu Jul 27, 2023 1:26 am
After I installed the development board and imported the configuration data, I found that the bridge option does not include the Realtek network card. I have tried uninstalling the network card driver and reinstalling it, is there any way to solve this problem? If it's too hard, I can use a Mellanox CX341A as a bridge.
Post by solo » Thu Jul 27, 2023 7:51 am
Interesting, please run as admin and post as code:
PS> Get-NetAdapter | Format-List -Property ifAlias,InterfaceDescription,PromiscuousMode
Yes, go for the Mellanox.
LeeHS
Post by LeeHS » Thu Jul 27, 2023 12:08 pm
Name InterfaceDescription ifIndex Status MacAddress LinkSpeed
OpenVPN TAP-Windows6 TAP-Windows Adapter V9 21 Disconnected 00-FF-... 1 Gbps
VMware Network Adapte...1 VMware Virtual Ethernet Adapter for ... 19 Up 00-50-... 100 Mbps
OpenVPN Wintun Wintun Userspace Tunnel 16 Disconnected 100 Gbps
Ethernet Realtek PCIe 2.5GbE Family Controller 13 Up 2C-F0-... 2.5 Gbps
Local connection Kaspersky VPN 10 Disconnected 10 Gbps
Bluetooth network connection Bluetooth Device (Personal Area Netw... 9 Disconnected 8C-C6-... 3 Mbps
OpenVPN Data Channel O... OpenVPN Data Channel Offload 8 Disconnected 1 Gbps
VMware Network Adapte...8 VMware Virtual Ethernet Adapter for ... 3 Up 00-50-... 100 Mbps
For security reasons, I replaced part of the MAC address with "...", I hope it will not cause any inconvenience.
Post by solo » Thu Jul 27, 2023 12:28 pm
Something ain't right with your output, I get for example...
ifAlias              : VPN - VPN Client
InterfaceDescription : VPN Client Adapter - VPN
PromiscuousMode      : False
ifAlias              : Wi-Fi
InterfaceDescription : Killer(R) Wi-Fi 6 AX1650x 160MHz Wireless Network Adapter (200NGW)
ifAlias              : Ethernet
InterfaceDescription : Realtek Gaming 2.5GbE Family Controller
As you can see my Realtek does not qualify for a SE bridge. Another rejection reason is binding to VM adapters like your VMware.
LeeHS
Post by LeeHS » Thu Jul 27, 2023 1:45 pm
ifAlias              : Wi-Fi
ifAlias              : Ethernet
Oh, sorry. I missed the command after "Get-NetAdapter".
ifAlias              : OpenVPN TAP-Windows6
InterfaceDescription : TAP-Windows Adapter V9
ifAlias              : VMware Network Adapter VMnet1
InterfaceDescription : VMware Virtual Ethernet Adapter for VMnet1
ifAlias              : OpenVPN Wintun
InterfaceDescription : Wintun Userspace Tunnel
ifAlias              : Ethernet
InterfaceDescription : Realtek PCIe 2.5GbE Family Controller
ifAlias              : Local connection
InterfaceDescription : Kaspersky VPN
ifAlias              : Bluetooth network connection
InterfaceDescription : Bluetooth Device (Personal Area Network)
ifAlias              : OpenVPN Data Channel Offload
InterfaceDescription : OpenVPN Data Channel Offload
ifAlias              : VMware Network Adapter VMnet8
InterfaceDescription : VMware Virtual Ethernet Adapter for VMnet8
Post by solo » Thu Jul 27, 2023 2:32 pm
I don't like this one, it may be scanning your net traffic and causing the BSOD. On a bridged interface do unbind EVERYTHING except for "IPv4" and check for BSOD.
LeeHS
Post by LeeHS » Thu Jul 27, 2023 4:01 pm
But I don't have Kaspersky vpn enabled. In fact, it is not connected, including normal times. I only enable it if I need to change the network region. Or would that have an effect?
Post by solo » Thu Jul 27, 2023 4:21 pm
What about Kaspersky AV? In fact, disable any AV for the duration of BSOD tests.
LeeHS
Post by LeeHS » Thu Jul 27, 2023 4:30 pm
Still running, haven't had a blue screen in days.Still, I'm not willing to give up my computer's security. Maybe I should prepare VM
Post by solo » Thu Jul 27, 2023 4:35 pm
You can't be serious. It's only "for the duration of BSOD tests".
