Does any server provide SOCKS protocol?
phil
Post by phil » Thu Aug 03, 2023 8:52 am
Beside L2TP/IPsec OpenVPN,
Dose any server provide SOCKS or SSH protocol?
Re: Does any server provide SOCKS protocol?
Post by solo » Thu Aug 03, 2023 9:21 am
phil
Post by phil » Mon Aug 07, 2023 4:04 pm
Thanks,
according to the document, VPNGate provide Socks4 by default,
but which port should I connect?
Post by solo » Mon Aug 07, 2023 5:17 pm
No. It's SOCKS in the context of SoftEther clients.
To connect to VPN Server via a SOCKS proxy server, select [Connect Via SOCKS Proxy Server], and then click [Proxy Server Connection Setting] and enter the required information. For more information about the settings on the [Proxy Server Connection Setting] window, please contact the administrator of the SOCKS server.
https://www.softether.org/4-docs/1-manu ... VPN_Server
phil
Post by phil » Tue Aug 08, 2023 8:07 am
------I don't use Windows, only Linux and Android, and I belive there is not way to connect directly to these L2TP/IPsec/OpenVPN servers from China, So if there are SOCKS server, I can relay the connection.
-------How can I contact them? There is not contact information on the list.
BTW, Dose SoftEther has the same SOCKS port by default?
--------No information about Socks port in this document (Or did I missed it?)
Post by solo » Tue Aug 08, 2023 9:27 am
If there are such servers, "contact the administrator of the SOCKS server" about port number.
